Backfiring
Old Sep 4, 2007 | 10:09 AM
z28 justin's Avatar
Backfiring
I took my car to the track Friday and after the second run it started backfiring a bit, so I called it a day. (Mods listed in sig) I'm wondering what exactly could cause this? The opti, plugs, and wires are all only a year old. So I doubt ignition is the problem. It's not throwing any codes. I don't know if the O2 sensors have ever been changed, but if they were not functioning correctly wouldn't they throw a code? Any feedback would be appreciated, thanks guys.
Old Sep 4, 2007 | 10:39 AM
Bird_Of_Prey's Avatar
Backfiring is unburned fuel hitting the exhaust. I would start with the igntion, even though you've convinced yourself it can't be the problem...
Old Sep 4, 2007 | 03:51 PM
fattyz28's Avatar
I don't know if it will help, but you might try a tune if you don't have one already. I have read posts about some exhaust popping going away afterwards. If nothing else it should run better anyways. MADZ28.com has a very fair price for their tunes. I felt as if Ion did me right. Bird is probably right, don't rule it out.
Old Sep 5, 2007 | 08:34 AM
z28 justin's Avatar
Well, the previous owner did all the engine mods and had it dyno tuned. I guess my question would be now, if it's not the 02 sensors, how can I test the opti? The plugs are brand new and the wires look good. I replaced my pushrods a couple months ago, but it ran fine right after that, so I'm also going to readjust my rockers just to be sure.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Dzmaro
Jun 19, 2015 11:38 AM
Chet1185
May 10, 2015 09:24 AM
