backfire when under load please help
Old Apr 29, 2010 | 08:22 PM
smoka stang's Avatar
car will sit and ilde fine all day long once you put it under load it backfires by backfire I a loud pop out the exhaust . Its very random it might do it once in a minute or 5 times . Just about everything on the car is new . Everthing listed is new : Opti,ICM,coil,plugs,wires,fuel filter, . The fuel pressure stays around 35 may go up to 38 or 39 but falls no less than 35 psi. I was gonna change the fuel pump but not sure if its the problem . Not showing service engine light or any codes on the scanmaster. Im not sure what to do ive triple checked everthing . Someone told me could be a stuck valve and to double check the valves. Everyones imput is greatly apreciated
__________________
Old Apr 29, 2010 | 08:30 PM
dangalla's Avatar
is it missing?
pretty sure fuel pressure should be 43.5 psi, no more no less and dropping that low could be an issue, or an inaccurate gauge
your issue sounds like a spark miss though, do you have any codes? not just a light you need to actually scan it
what brand opti did you use?
what plugs did you use and what were they gapped to?
and wire type?
Old Apr 29, 2010 | 08:42 PM
its a gm opti . they are ngk plugs gapped at 40 or 43 i think . I have a lt1 scanmaster and it isnt showing any codes . looks like it has good spark . as far as fuel pressure ,I was told being off by 8 psi shouldnt have much of an effect but that what I was leaning toward myself . The car seems to have good power .
Old Apr 29, 2010 | 10:01 PM
It idle, with vacuum compensation line off the fuel pressure regulator, should be 43.5psi, with anything in the range of 41-47psi meeting GM spec. Attach the vacuum line, and it should drop about 5psi below the "no vacuum" reading.
It should hold at least 40psi under full RPM/load. Running at 35psi would reduce fuel flow by about 10%.
If its misfiring, the air and fuel will end up in the exhaust, and it may light off and pop.
Old Apr 30, 2010 | 11:22 AM
Sorry for the double post . So it may be worth it to change the pump ? I will try what u said to do and see where its at . I appreciate your response
Old Apr 30, 2010 | 03:15 PM
i checked fuel pressure with vaccuum off it was at 39 psi and as soon as its hooked back up its 35
Old Apr 30, 2010 | 04:37 PM
Was the vacuum line dry - no fuel in it?
Old Apr 30, 2010 | 04:43 PM
no fuel lots of vaccuum though
Old May 3, 2010 | 03:50 PM
any other ideas. or would changing the fuel pump be the best bet
Old May 3, 2010 | 04:12 PM
red 95 z28 lt1's Avatar
try disconecting the maf and see how it runs, just a shot in the dark here
Old May 7, 2010 | 09:38 PM
I think I may have found my problem . I have 2 lifter that are bad I can push on the pushrod and push the lifter right in . I have the Hotcam its possible they are still the stock lifters right . Ive been doing some reading and people are using LS7 lifters should I use them or what would be reccommended and where can I get them
Old May 7, 2010 | 09:51 PM
dangalla's Avatar
the ls7 lifters are not the standard replacement for an lt1, so yes - use them
you can get them pretty much anywhere, look around to find the best price
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
form94
Sep 23, 2015 07:30 AM
tommalcolm
Sep 11, 2015 03:39 PM
