Backfire issues?
Old Jul 3, 2006 | 09:59 PM
BassProCamaro97's Avatar
Question Backfire issues?
Anyone ever have backfire problems with LT and before axl dumps? I just got everything finished finally on the car and it backfires everytime i let off the gas. It's not real bad but more like a louder gurgulling sound. Anyone else ever expirence anything like this?
Is it normal or an ignition issue?
I used the search and came up with mixed answers
Thanks in advance
Old Jul 3, 2006 | 10:02 PM
30696bird's Avatar
Re: Backfire issues?
Do you have a x-pipe? If not I believe the uneven backpressures cause this. Just a guess. If you do have one look for exhaust leaks. Mine does not backfire UNLESS I have a leak around the collectors.
Old Jul 3, 2006 | 10:13 PM
I have an H. I didnt hear any exhaust leaks prior to the dumps being setup.
Old Jul 5, 2006 | 04:54 AM
Guest47904's Avatar
Guest
Still have the air pump?
Old Jul 5, 2006 | 08:12 AM
No AIR, nn EGR and no cats. It seems like its running rich but i haven't put more then 50 miles on it yet. It doesn't seem to backfire in the lower RPM's when you let off but anything around 3-4 and it does.
Thanks for the help
Old Jul 14, 2006 | 02:59 PM
can anyone else help me out?
Old Jul 14, 2006 | 09:04 PM
matt65's Avatar
I get a VERY loud pop (like a gunshot nearly) if I accel hard, then realease thottle quickly. Esp when cold..air pump mentioned earlier.
I have LT Pacesetters, ORY, single Dynomax (for the time being), no cats, no resonator, and 3inch turndown in front of the axle.
I have not let the pop bother me as I can prevent it with the accel pedal.
A new exhaust (probably quiter) will be on the way with heads and cam.
I cant explain why, but mine will act differently on this issue based on the octane of fuel used.
Chet1185
May 10, 2015 09:24 AM
Drtryder
Apr 22, 2015 04:17 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
F(ast)-body
Feb 26, 2003 09:05 AM
BAD BLACK WS6
Classic Engine Tech
Jun 8, 2002 02:06 PM
