Backfire help!
Old Aug 20, 2003 | 01:45 PM
bigfoot2471's Avatar
Backfire help!
today i took my car to the shop to have it looked at they told me abosultely nothing besides my car reads the battery at 1.5 volts lower then it really is. now i get home reving to see what happens i get a bog which happens when car is hot and it backfires. i rev it up 5 or 6 times prob 3 times it backfired. i was thinking bad opti and this shop didnt know much about it. can a bad opti cause backfiring. I really dont like having to go to a dealership to get this all fixed they charge up the @ss. thanks for the help
Old Aug 20, 2003 | 09:49 PM
ttt
Old Aug 20, 2003 | 10:31 PM
Since the opti has everything to do with spark timing, yes, it can cause backfiring. If you are talking about popping when you let OFF the gas, then that is not really backfiring.
Old Aug 21, 2003 | 12:19 AM
Thanks for the response but no it is as i first step on the gas that it happens.
Old Aug 21, 2003 | 08:33 AM
speed76demon's Avatar
do the simple stuff first. change your plugs and wires that partially solved my problem then the opti solved the rest but maybe you'll get lucky
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Dzmaro
Jun 19, 2015 11:38 AM
Chet1185
May 10, 2015 09:24 AM
