Back firing issue.. whats the deal??
Old May 30, 2005 | 02:48 PM
flusz28's Avatar
Okay i had my motor apart for acouple months, because the water pump elbow you had to move for the vortech blower install came lose and fell out and car over heated and blew my head gaskets/warped heads. had heads cleaned up and ported/new gaskets of course. then just changed up the piping for the blower alittle and bolted on a BOV. other then that nothing has changed motor wise... now when i start it up it will randomly back fire while sitting at idle?? no check engine lights or anything.. now i have brand new cheap autolight autozone special plus installed for the time being until i'm ready for the dyno tune then i will add my new NGKTR6 plugs. could the spark plugs be getting to hot from the peformance wires and msd box and causing a issue? they are gapped at the stock gap..
Old May 30, 2005 | 02:53 PM
flusz28's Avatar
Re: Back firing issue.. whats the deal??
also- when i give the car gas it doesn't show and sign of backfire but after i left off the gas/this is at like 2200 then a min later it will backfire
Old May 30, 2005 | 09:00 PM
sw89lt1's Avatar
mine did the same thing when the sparkplug wires were crossed.
Old May 31, 2005 | 06:08 AM
flusz28's Avatar
hmm it could be that or the BOV could be holding air back. it didn't make any noise when i first started the car up without the blower connected. so spark lugs are ruled out on that one. thanks
Old May 31, 2005 | 09:43 PM
sw89lt1's Avatar
mine did not start poping until it warmed up.
Old May 31, 2005 | 09:54 PM
flusz28's Avatar
so what was it and how did you fix it. could i have a plug wire mixed up?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DetroitZ28
Feb 13, 2015 07:33 AM
nophix
Nov 30, 2014 10:26 PM
