1995 LT1, 381cid, lt1 edit question
Old May 31, 2005 | 09:56 PM
busta9876's Avatar
I about have my new LT1 finished and I am looking at options for the PCM. I have used a Do It Yourself fuel injection system called Megasquirt (http://www.megasquirt.info) on a few other motors i have, and considered doint it for the lt1, but I have the 95 ecm and complete harness.
does anyone have some screen shots from LT1 Edit of the fuel tables and the spark tables? can you tune it in speed density using VE tables?
What will i need to do to the ECM to get it fired on the 95 GM ECM
here's what I got
1995 LT1 engine, stock heads w 2.00 1.56 valves, some porting, GM LT4 hot cam, 1.6 rockers, eagle 3.75 stroke crank, eagle 6" rods, srp -16cc dish pistons. .020 overbore = 381 cubic inches.
i've been told that the LT4 cam will run fine on a stock computer, that the MAF will correct for the cam. now i have more cubes, and dont know for sure.
anyone running a N/A 383 with a lt4 cam? anyone have a LT1 edit file of their tune i could look at?
Thanks!!!
Brendan Patten.
www.lt1swap.com some of my projects!
calaban
May 18, 2020 06:43 PM
joe777107
Dec 1, 2014 09:32 AM
Burn_Out
Aug 18, 2002 08:49 AM
Skull Leader
Aug 10, 2002 11:01 AM
Bando
Aug 2, 2002 02:18 PM
