Back firing!?!?!?!
Old Feb 1, 2006 | 08:29 PM
Heatmaker's Avatar
Advanced Member
Back firing!?!?!?!
My car back fires violently when you dive after starting it up... before the 02's are actived by the PCM, and I'm guessing it's running rich... for this to happen.... Gas consumption is down the drain.
I replaced the MAP sensor.. and now my busted IAC is showing it'self since the car wont idle under 1500 not sure why that happend... after I replaced the stock GM unit... since it idle at 1200with the broken IAC still.
I'm at my wits end, and still the car seems to be flattening out on the accelorator at higher RPMs... my exahust tips are super black from this after I polished the hell out of them, which is unusual.. something is up.
Old Feb 1, 2006 | 08:42 PM
Guest47904's Avatar
Guest
Re: Back firing!?!?!?!
When was the last time you checked your cotton filter?
Old Feb 2, 2006 | 09:18 AM
Heatmaker's Avatar
Advanced Member
'whats a cotton filter?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DetroitZ28
Feb 13, 2015 07:33 AM
Jazsun
Dec 29, 2014 12:14 PM
nophix
Nov 30, 2014 10:26 PM
