B&M trans cooler
Old Jun 24, 2003 | 08:27 PM
Blk94Z28LT1's Avatar
B&M trans cooler
I'm getting ready to install a B & M trans cooler and the instruction say you have to hook the pressure and return lines a certain way. Gives you a list of transmissions and which line is pressure and return, except the 4L60E isn't in the list.
So, is top radiator line pressure and bottom return or vise versa.
Old Jun 24, 2003 | 08:32 PM
revtime's Avatar
Top line is return, I went with the fact that 4L60E is basically a 700R4 with electronic controls and used the top line as return.
I cut off the crimped hose with a tubing cutter and hooked it up there, did not have to use the brass couplings that way and the install looks alot cleaner. I don,t have AC and took the condenser out so I had lots o room and the little bracket on the bottom of the radiator that held the line for the condenser works great to hold your rubber line for the cooler.
Old Jun 24, 2003 | 09:52 PM
EviLBoX's Avatar
Here's a pretty good guide if you need it. It's not a B&M, but it's the same idea.
http://www.bfranker.badz28.com/94z/trannycooler.htm
james007moore
Jan 1, 2016 01:14 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
CARGASM
Sep 4, 2002 11:17 AM
