axel removal to replace wheel studs?
Old Dec 11, 2003 | 06:16 PM
formulaofsuccess's Avatar
so today i took a look at the wheel studs i need to replace on my rear hub and it looks as if its not as simple as pounding out the old and throwing in the new. seems part of the tcs or abs is in my way to get the bad stud out and i'm guessing part of the axel needs to be slipped out to gain the necessary clearance? anyone have any info on this?
Old Dec 11, 2003 | 06:21 PM
JPSartre12's Avatar
Re: axel removal to replace wheel studs?
I replaced 2 studs on my 94 Z last weekend. If your car is similar to mine, it's a piece of cake. Just lift both wheels off the ground and rotate the wheel until the stud you want to bang out is at ~8-10:00 position,IIRC. You should have an easy time of pounding it out when it's in that position.
Old Dec 11, 2003 | 06:22 PM
i dont know about on yours but on mine there is a toothed gear that sits just behind the hub and the studs...that's the piece that i cant seem to clear! did you have that issue?
Old Dec 11, 2003 | 06:26 PM
94formulabz's Avatar
sounds like he has a 4 channel abs car so there is a tone ring on each axle.
I'm not sure how to change them. I think you may be right though that you need to remove the c-clip, axle, then slide off the tone ring and eventually re-press it on. sorry i don't know more about this.
-brent
Old Dec 11, 2003 | 06:59 PM
95LT1Z28's Avatar
You have to pull the TCS reluctor ring gear off the axle in order to replace a wheel stud. You will have to pull the axle out and bring it into a shop to have the "toothed" gear taken off and pressed back on. Just a major hassle of having TCS.
Jeff
alphaauto
Jan 23, 2015 07:42 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Catmaigne
Dec 25, 2014 12:16 PM
pologreen97z
Dec 2, 2014 10:42 AM
