Axel part number
Old Apr 22, 2003 | 12:00 PM
scoobysnax83's Avatar
Axel part number
Just wondering what the part number is for a rear passenger side axel. I also need the name/part number for the small ring things (real descriptive, I know ) that go inside of the differential and rest between the axel gear and differential housing. Thanks everyone.
O yeah and Steve don't worry when you come acrossed an axel I still plan on buying from you. I'm just curious about the part numbers.
Old Apr 22, 2003 | 06:56 PM
where you at shoebox?
Old Apr 22, 2003 | 07:06 PM
n2ceptor's Avatar
Shaft, rear axle part # 26063146
Are you asking for the C-clip?--part # 344171(may be an old #)
Old Apr 22, 2003 | 07:23 PM
Hey thanks for the part number. How bout we do this. Does anyone know all the stuff that I need to replace an axel. In other words the bearings and preventative maintenance stuff associated with this procedure. Thanks
Old Apr 22, 2003 | 07:44 PM
n2ceptor's Avatar
Rear Diff cover gasket
2 axle bearings and axle seals(should go ahead and do both sides)
2 quarts of diff fluid and limited slip additive(usually 4oz bottle)
Reuse C-clips if not worn/scuffed/bent..etc..
Bearings, seals, gasket, and fluids can be at local parts store.... C-clips unsure..
Hope this is what you are referring to....
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
