autozone ICM???
Old Dec 31, 2010 | 06:55 PM
camarorz28's Avatar
autozone ICM???
what is your experience with ICM from autozone. I purchased not even a year ago and today i took it to get tested and it was dead. i got a new one threw warranty. what would kill the module???
Old Dec 31, 2010 | 07:10 PM
ASTROJOE LT1's Avatar
Re: autozone ICM???
I have been running a Wells brand one from Autozone for 7 years. I just had mine tested last week because I thought I had a problem with it, but it was tested good. What would kill one. Bad Luck Maybe
Old Dec 31, 2010 | 08:54 PM
byrons1502's Avatar
Re: autozone ICM???
I stay as far away from anything that moves or electricity runs through it as far as getting anything from autozone. U will hear both sides but i would recommend against it. I do this for a living and seen way to many bad parts from there.
Old Dec 31, 2010 | 11:58 PM
my1994z28's Avatar
Re: autozone ICM???
Heat will kill the ICM,try putting a few washers between the coil bracket and the head..I have a ICM from Autozone,been going strong for 5 yrs..
Old Jan 1, 2011 | 12:23 PM
camarorz28's Avatar
Re: autozone ICM???
94z28,
when i replaced the previous oem module i rigged the coil for space in between. I put two washers on each stud.
Old Jan 1, 2011 | 05:32 PM
95mysticta's Avatar
Re: autozone ICM???
When it comes to ignition you do not want to cheap out on them. As this saying goes "LT1s are spoiled girls, you cant buy the cheap stuff and expect them to be happy". Go out and buy a factory Delco unit or find a used one on the forum for even cheaper. If you do buy an Autozone you cant expect it to last so your the fool wasting your time and money and will have to buy the proper one later.
Old Jan 1, 2011 | 06:12 PM
94Camaro_Z_28's Avatar
Re: autozone ICM???
The Autozone one is more than fine. Just an FYI, while working at a GM dealership, it became pretty damn obvious that the Delco stuff is not any higher quality and it's seriously time to stop kidding yourself. Many, many, many Delco filters are rebranded Premium Guards, which are cheap *** China made filters. I'm certain many other parts follow suit as I've had just as many parts failures with Delco parts as I have Jim Billy Bob's Ignition Warehouse parts.
Don't waste your money, just buy the AutoZone part.
As for what can kill it, heat is the #1 issue. As stated, space the ICM away from your head with a few washers.
Old Jan 1, 2011 | 06:43 PM
bw_hunter's Avatar
Re: autozone ICM???
How do you know they're rebranded filters? I'd like to be able to tell next time I need a filter.....
Old Jan 1, 2011 | 07:11 PM
Re: autozone ICM???
Exact same part numbers on the packaging. The Premium Guard filter for a Silverado was 5314. We got a shipment of Delco air filters in. They weren't in boxes, they were wrapped in plastic. They had Delco 1518 stickers on the packaging with the part number 5314 printed on the filters themselves, as well as made in China. I'm not sure if it was something that was a one time deal or what, I left the dealership shortly after. Needless to say, I was not impressed in the least. These filters had almost half the pleats of the normal Delco and an incredibly flimsy gasket.
Also, Premium Guard produces Purolator filters. Check their part numbers for yourselves. The Purolator will always have the same Premium Guard part number with 2 added digits.
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
