Autometer guages(oil/temp) use stock senders?
Old Jun 10, 2006 | 07:26 PM
Jameslt1TA's Avatar
Hey guys i would like to put some autometer guages in the a/c vent in the center of my dash. I will be gettting trans temp, water temp and oil press. My question is will they be anymore accurate than the stock ones(oil/water) if i just get the electric over manual ones and hook them up to the stock sending units. Or should i just go with the good old fashion manual ones and string plastic hose all over the place?
James
Old Jun 10, 2006 | 07:33 PM
SnakeOiler's Avatar
Re: Autometer guages(oil/temp) use stock senders?
I've had mechanical ones and I've had electrical ones. I like the electrical much better.
You cannot connect the guages to the stock sending units - that will not work. You need to use the sending units that come with the guages you buy.
Old Jun 11, 2006 | 12:45 AM
1quikZ's Avatar
what he said^ however i prefer the mechaincal
Old Jun 11, 2006 | 02:16 AM
1racerdude's Avatar
You will have to get the Autometer senders for them to read accurately.
Old Jun 11, 2006 | 02:10 PM
Jameslt1TA's Avatar
Sounds good i guess ill get the electrical since it would be a ton easier to run to the a/c vents.
Thanks guys
James
Old Jun 11, 2006 | 02:21 PM
I have both electric (fuel pressure) and mechanical (oil pressure, nitrous pressure) in the center A/C vents. Its not that hard to run either. But,with the temperature gauges, a "mechanical" unit is a major PITA though. The sensor is a "bulb" and its connected to the gauge using a fixed length capillary tube. The tube and bulb can not be separated from the gauge, so you would have to thread the bulb and the tube through the firewall and the A/C ducting behind the center vents, and that would be a problem.
I have an electric oil temp sensor in the A-pillar, and I drilled and tapped the oil drain plug and threaded the oil temp sensor into there. For the coolant temp, there's the plugged hole in the passenger side head, between #6 and #8 (same as the one for the stock gauge sensor in the drivers side head). If you can't access that one because of headers or something, you can put a brass "tee" in one of the coolant lines and install the sensor there. I used the line from the back of the heads to the radiator on my 94, but the hose routing is different on your 95.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
GigaMp3z
Feb 20, 2003 02:57 PM
