Autometer electronic gauge senders?
Old Dec 30, 2005 | 10:44 AM
97Z-pimp's Avatar
I just recieved my autometer electronic oil temp and tranny temp gauges. I will be using the pressure plug on the driver side of the transmission for the tranny temp gauge. For the oil temp i will be using the port above the oil filter. My question is if the places that i have chosen will need adapters for the sending units, or if they will screw right into the block and tranny? Thanks.
Old Dec 30, 2005 | 11:48 AM
MEAN LT1's Avatar
Re: Autometer electronic gauge senders?
Most likely yes on both ends. Although I have not installed any one of these two guagesbefore. Never have I seen Autometer stuff come with everything you need. But those locations should work.
Old Dec 30, 2005 | 12:39 PM
97WS6SCharged's Avatar
Those types of senders are usually mounted in the pans, I don't know how accurate they will be in a pressure fitting. You may want to call Autometer before you install them.
Anybody riding this Sunday/Monday?
Old Dec 30, 2005 | 03:42 PM
Everett's Avatar
i have the autometer trans temp in the same place you are talking about and it fit perfect. no adapter needed. the plug above the oil filter is 1/4 NPT so it think it would be fine as well. The only thing i noticed about my tranny temp gauge is it runs about 20 warmer than what the pan temp is.
Shane
Old Dec 30, 2005 | 03:59 PM
97Z-pimp's Avatar
A lot of people on the board here have put the senders in the places i have said, but as i look at shoebox's site, the pressure plug on the tranny is a 1/8 NPT and the sender is a 1/4" NPT. So is there an adapter for that?
Chris, if you want to ride sunday or monday send me a pm.
Old Dec 30, 2005 | 04:33 PM
Everett's Avatar
i didnt have to use an adapter at all for my tranny temp sensor. it screwed right into the tranny case. i dont have an oil temp but i am running the oil feed line for my supercharger from the port above the filter and it is 1/4 npt.
shane
Old Dec 30, 2005 | 10:26 PM
My Iroc Z28's Avatar
you will need a adapter for the oil temp. it's included in the kit with the gauge so you will be fine. If im not mistaken its the smallest one in the kit.
Old Dec 30, 2005 | 11:03 PM
97Z-pimp's Avatar
You guys are right. I finally realized that the different adapters are included. Thanks for the help.
Everett- what tranny temps do you normally see while crusing?
Old Dec 31, 2005 | 08:42 AM
Everett's Avatar
moving in the summer it goes from 170 to 190 all depending on how i am running the car. this fall when the temps went down it wouldnt get above 120.
Shane
Old Dec 31, 2005 | 09:24 AM
97Z-pimp's Avatar
Thanks Shane
Old Dec 31, 2005 | 11:21 AM
Everett's Avatar
Not a problem
Quickss96
Jan 29, 2016 05:56 PM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
4586
Jul 31, 2015 06:03 PM
