Which Autolite plug for this setup?
Old Jun 25, 2004 | 12:19 PM
350 HRSS's Avatar
Getting ready to do plugs in the LT1 again. I have Autolite 106's
in there right now. I like them, I just want to know if they are the best application for my set up, 95 Z
CC306
GTP Stage II heads
Vigi 2800
MSD 6A, Blaster GM coil
And more, etc. I just know that the heads and cam are the most
important factor!
BTW, what should the gap be? I think mine are at .35 right now.
Thanks!!
Need to know ASAP!
Old Jun 25, 2004 | 12:38 PM
gamecockfan04's Avatar
The 106's are fine for your setup, unless your using nitrous, but I would recommend the platinum, or double platinums. Ive got the regular 106's in now, but Im going to change them soon to the platinum 106's and Im pleased with the Autolites so far as well, and I switched from NGK's, which I was not impressed with them at all.
Old Jun 25, 2004 | 12:48 PM
350 HRSS's Avatar
The platinum? Really???
What makes them so much better than copper?
And that is gapped at .35, right?
Old Jun 25, 2004 | 01:04 PM
Loadre's Avatar
Personally I would widen the gap back out to .040 or so. .035 is pretty much the norm on nitrous motors when blowing out the spark is a concern, so it's probably a tad tight for a NA motor.
Old Jun 25, 2004 | 01:13 PM
350 HRSS's Avatar
The reason I asked is b/c Chiltons says .35 for a 95Z. Are you suggesting .40-45 b/c of my CC306?
Chiltons says .35 for a 95 Z28. Now, you may be thinking about the 95 3.4, which says .45 gap.
Old Jun 25, 2004 | 01:15 PM
.035??? The stock GAP is .050, so I wouldnt go lower than .045. The platinum plugs are what came stock in the LT1's(Delco's) and they last longer and will get you better gas mileage, performance..etc., just overall a better plug.
Old Jun 25, 2004 | 01:24 PM
Loadre's Avatar
I think you are mistaken. Stock gap is .050.
Old Jun 25, 2004 | 01:32 PM
Maybe the .035 is for a V6, but yes the stock gap for the LT1 is .050.
Old Jun 25, 2004 | 01:35 PM
350 HRSS's Avatar
Page 1-54 Chiltons GENERAL INFORMATION AND MAINTENANCE
GASOLINE ENGINE TUNE-UP SPECIFICATIONS
1995 Engine VIN P SPARK Plug Gap .035 FUEL Pump PSI 41-47
I am not argueing with you guys, I am just telling you all what the Chiltons that I have, says.
Old Jun 25, 2004 | 01:39 PM
350 HRSS's Avatar
I think the Chitons is confused. For the 3.4 it says .45 GAP.
Like I said, I am not disagreeing, just trying to figure out why this manual says different.
Old Jun 25, 2004 | 01:51 PM
Has to be a typo. My Hayes manual says .050 along with my car manual.
Old Jun 25, 2004 | 02:42 PM
350 HRSS's Avatar
I hope it is a typo, b/c I know it sounds crazy. That is the main reason I asked.
If anyone else has a Chiltons, check it out.
grgguy
17
Feb 23, 2015 07:57 PM
blac94Z
Feb 23, 2015 04:29 PM
KASR_Z28
Aug 6, 2002 03:34 PM
Paulberg
Jul 26, 2002 11:35 AM
