auto radiator in an m6
Old Dec 5, 2003 | 09:52 PM
96SSM6's Avatar
My radiator cracked a few days ago. I got a new one from this guy, but it had the two extra holes in it for the trans cooling lines. I have a m6. Can I just cap those holes and use it?
Old Dec 5, 2003 | 10:01 PM
93formula's Avatar
yup
Old Dec 5, 2003 | 10:51 PM
96z's Avatar
96z
I didnt even cap mine and it still works just fine.
Old Dec 6, 2003 | 07:05 AM
TransAm9585's Avatar
RAD
It will work just fine, those two holes are for the stock tranny cooler lines on a auto. Its basically just cooler inside a cooler. Just leave m and go. ALthough capping them off wouldnt hurt in case in the future you decide to sell the radiator keeps things inside clean.
Old Dec 6, 2003 | 09:13 AM
96SSM6's Avatar
Thanks for the help guys. Hopefully I'll be back on the road tonight.
Old Jan 21, 2004 | 04:15 PM
OBE1 95Z28's Avatar
If you use an A4 radiator in a M6 car, do you loose some cooling surface area because the bottom of the radiator is not used (tranny cooler section)?
Old Jan 21, 2004 | 04:37 PM
You shouldnt loose any cooling efficency from that system. Fluid from the tranny doesnt actully flow through the fins it flows into a bladder system so to speak of inside radiator tank on the passenger side. in theory it uses heat transfer from one fluid type to another and circulation to keep it all cool.
Old Jan 21, 2004 | 04:56 PM
AdamZ1LE28's Avatar
yea i also have an a4 radiator with my m6 tranny. no problems with it at all......
Old Jan 21, 2004 | 07:29 PM
961le's Avatar
Smile
the autos hold just a tad less coolant. i have a m6 with an auto rad no problems
Old Jan 21, 2004 | 08:03 PM
AdamZ1LE28's Avatar
look at this....theres 2 of the 55 '96 1le's in this post. haha
AdamZ1LE28's Avatar
AdamZ1LE28's Avatar
Old Jan 22, 2004 | 07:16 PM
961le's Avatar
Talking
adam, what options did your car come with
Old Feb 3, 2004 | 09:58 AM
OBE1 95Z28's Avatar
I bought a 4th Gen radiator on autobodypartsonline and can't be happier with the fit and quality! It's designed for both autos and M6's (hook-ups for the tranny cooler and stock oil cooler. It was $121.95 plus tax/shipping (total in CA was $140). All fittings are in the original locations.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Fatdog2
Apr 27, 2015 10:32 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
