auto meter guages
Old Feb 23, 2004 | 10:07 PM
blazzinbird's Avatar
auto meter guages
can anyone give me any tips to installing my autometer guages
water temp
oil pressure
the instruction they give you is more of a scamatic, if someone could help me find where to put the sender for both i would be happy. For somereason i am having major brain farts and cant think to clearly right now, so please help
Old Feb 23, 2004 | 10:11 PM
Bryan 94 Z28's Avatar
Water temp = Save yourself some hassle and just ditch the stock sender. Use the stock sender's threaded hole in the driver's side head, between the number 1 and 3 cylinders' exhaust ports, I believe. There is a fitting that came with your gauge if you got it new that will let you do this.
Oil pressure = Use the threaded port just above the oil filter on the block. Just take the plug out of the block and use it. Again, there will be fittings in the gauge if you got it new that will allow you to do this.
Old Feb 23, 2004 | 10:13 PM
thanks that is what i was thinking
Parts Wanted
May 1, 2016 10:25 AM
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
