ATI Harmonic Balancer Shell Aluminum vs Steel
Old Mar 6, 2015 | 10:19 AM
Red_94Formula's Avatar
ATI 917270 uses the steel shell (9.75 pounds) and ATI 917268 uses the aluminum shell (6.75 pounds). I would like to use the lighter one but I do not want to interfere with eliminating harmonics. I read on net that the steel version is better at eliminating harmonics. Is this true?
I making a 385 that may go to 7k rpm.
Derek
Old Mar 6, 2015 | 12:55 PM
MEAN LT1's Avatar
Re: ATI Harmonic Balancer Shell Aluminum vs Steel
I have the steel one and love it. The aluminum has less mass and therefore weighs less. Not really what you want from a drag racing stand point. Im sure others will give you their opinion on the version they have.
Old Mar 7, 2015 | 09:21 AM
cnorton's Avatar
I've used the aluminum shell and the aluminum hub on my NHRA Stock Eliminator combinations running up to 7300 with no problems. After consulting with ATI, I decided to stay with steel components on my LT1 Super Stock combination that was regularly seeing RPM at 8000+.
c
Jul 31, 2015 06:03 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
JCSWS6
Jul 19, 2015 06:47 PM
