ATI balancer, which hub bolt and washer?
Old Mar 14, 2010 | 11:51 AM
ponyackn's Avatar
Question ATI balancer, which hub bolt and washer?
I have an ATI harmonic balancer, but I need a new hub bolt and washer to pin it down. Anybody have a part number or know of the size I need for both the bolt and washer? Where did you get yours? All I know is that the washer needs to be thicker than the stock stuff and apparently, the bolt will be larger as well.
Old Mar 14, 2010 | 01:24 PM
cnorton's Avatar
I usually use ARP #234-2501. I like the larger hex because it's easier to keep a socket on it if you need to turn the motor by hand. Also, carefully check the length. It's made for a traditional small block and some of those cranks are threaded deeper than the LT1. I have had to trim a few thousandths off the end of the 2501 on a few occasions.
c
Old Mar 14, 2010 | 01:42 PM
ponyackn's Avatar
Perfect!! Thanks cnorton. I searched that and got this:http://www.summitracing.com/parts/ARP-234-2501/
It looks like the thicker washer I'll need to.
Old Mar 14, 2010 | 07:27 PM
SnakeOiler's Avatar
That's also what I use with my Fluidampr
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Red_94Formula
Mar 7, 2015 09:21 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
