ASR + OBD1 Conversion
Old Nov 4, 2004 | 10:25 AM
Tibbys96Z's Avatar
I did the pcm conversion on my96Z A4 with ASR. Now when the asr is on and I rev the engine the asr ingages and the low trac light comes on. If I turn off the asr everything is good. Ion (madz28) told me that the asr doesn't run off the pcm, it has it's own module. Anyone have any suggestion on a fix, or is this a known issue?
Old Nov 4, 2004 | 11:52 AM
slopokrodrigez's Avatar
Re: ASR + OBD1 Conversion
Sounds like you have an issue similar to others that had ABS INOP from the ABS wires too close to a plug wire. See if they are and try seperating them with some zip ties.
Old Nov 4, 2004 | 04:56 PM
Tibbys96Z's Avatar
Interesting! I'll give it a try. Anything else to check?
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
tdigger9899
Sep 7, 2015 10:56 AM
