ASM Monoblade
Old Jul 29, 2004 | 01:19 AM
  #16
atljar's Avatar
Re: ASM Monoblade
The IAC counts are programmed into the ECM so that when you turn on the AC, they compensate. You can adjust that or remove it via tunerCATS / lt1edit
Old Jul 29, 2004 | 02:58 AM
  #17
SAR2K's Avatar
Thumbs up Re: ASM Monoblade
When I switched to the AS&M monoblade I also switched to a larger converter at the same time. Went from a 3600 to a 4400. RWHP gain was 10hp, I'm sure some of the gain was masked by the larger converter. The previous TB was an AS&M 52mm. Before & after dyno pulls were with in 24hrs of each other.
I didn't experience any idle or low speed driveability issues with the big TB. I highly recommend it for big cube & high RPM small cube applications.
Steve...
sleeperZ96BT
Sep 9, 2015 08:28 AM
MAKQSIK
Parts Wanted
Jun 11, 2015 04:30 PM
MEAN LT1
Jul 14, 2004 03:45 PM
93Z4ME
Feb 6, 2003 10:58 AM
IROCrdracer
3rd Gen / L98 Engine Tech
13
Aug 17, 2002 09:53 PM
