ASM Header Guys
Old Nov 15, 2004 | 04:28 PM
Fastbird93's Avatar
ASM Header Guys
Anyone having any clearance issues with the Y-Pipe Collector??? After the new motor and everything, I'm having some issues with it. Basically, it's now almost touching the floor pan just sitting there. The flange on the Y-Pipe collector/ORP is almost touching I should say. Any type of engine torquing acceleration or rouch shifting and it bangs the floor pan.
Just wondering if anyone has had a similar experience and if any resolution was met. Thanks.
Old Nov 15, 2004 | 05:05 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Re: ASM Header Guys
I never had problems,
Old Nov 15, 2004 | 06:27 PM
Fastbird93's Avatar
Re: ASM Header Guys
Neither did I until I had the motor out and back in. I'm wondering if there's an adjustment to the motor mount that needs to be done. I may be able to back the collector off some and angle it downwards some, but that's about my only option and I'll most likely end up with a leak at the collector if I do that.
Old Nov 15, 2004 | 06:56 PM
TUFF LT1's Avatar
Re: ASM Header Guys
Nope, I've never had any problems with mine. But, unlike you I've never pulled my motor out. Though I'm sure that technically I have with all of the repairs and mods that I've done on it. I would try to readjust the motor mounts though before I'd mess with the collector. I hate exhaust leaks! Good luck man.
Old Nov 15, 2004 | 07:19 PM
5.0THIS's Avatar
Re: ASM Header Guys
Never had any problems with mine
Old Nov 15, 2004 | 07:28 PM
Like My Taillights?'s Avatar
Re: ASM Header Guys
my header colectors and the y pipe collector both hit on my car after i first
installed the headers. Your motor mounts are more than likely sagging pretty good. I put a pair of poly mounts in and it has been fine ever since.. Good luck- Rob
Old Nov 15, 2004 | 07:35 PM
Fastbird93's Avatar
Re: ASM Header Guys
Hopefully I can adjust it. I really don't want to deal with chaging the motor mounts yet. It's always something with that car.
Old Nov 15, 2004 | 08:39 PM
marshall93z's Avatar
Re: ASM Header Guys
no problems here...
Old Nov 15, 2004 | 09:54 PM
Re: ASM Header Guys
Did you get the slip tube on all the way?
Old Nov 16, 2004 | 10:27 AM
Fastbird93's Avatar
Re: ASM Header Guys
Yeah, and that's where the problem lies. When it was on all the way, you could look at the flange and tell is was pointing upwards. Next opportunity I get I"m going to put the car on a lift and make some adjustments to it.
Jlo
Feb 23, 2015 12:20 PM
ModdedNerd
Feb 5, 2015 04:37 AM
Red97LT1
Aug 7, 2002 05:45 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
