aside from taking off AIR pump and lines... anything else?
Old Jan 15, 2006 | 10:42 AM
69z-28's Avatar
basic question, im doing longtubes and deleting my AIR when i get it tuned, so can i just rip/cut out all the hard/rubber lines and disconnect everything with that?
Old Jan 15, 2006 | 01:41 PM
LT1 POWR's Avatar
Re: aside from taking off AIR pump and lines... anything else?
Here is a good walk through site.
http://www.zmydust.com/airpump.html
Old Jan 15, 2006 | 05:07 PM
Your WS6 has a line that runs from the drivers side rear corner of the airbox to the AIR pump. You need a 5/8" vacuum cap to put over the nipple on the airbox. If you had the AIR pump recall work done on the engine, you need to cap off the vacuum line that comes off a "tee" on the driver's side of the intake, that also supplies the EGR solenoid vacuum.
Old Jan 15, 2006 | 07:02 PM
69z-28's Avatar
ok, i dont plan on deleting my EGR. SHOULD i delete for any reason? i have the race headers so there is nothing except the O2 bungs. i was planning on leaving the EGR system alone, but i will get it deleted if i have to i just need to know what needs to be done. what is the number 12 line in this drawing?...http://shbox.com/ci/AIR.jpg
its obviously not gonna work with my headers, so what do i need to do about it. i thought i had everything figured out but now im confused and worried. please help.
Old Jan 15, 2006 | 09:41 PM
Line #12 is the corrugated metal tube that runs from the exhaust manifold to the intake manifold. Since you do not have a place on #8 primary on your headers, you will delete that tube, and put a blanking plate over the back of the intake manifold where it used to connect. You can leave the EGR valve and the vacuum solenoid and the vacuum lines if you want. You can get a blanking plate from:
http://sjmmanufacturing.com
You have to have the EGR diagnostic deleted from the PCM or you will get an SES light/code. Or, there is a spoof circuit that can eliminate the code.
Old Jan 16, 2006 | 08:06 AM
69z-28's Avatar
o alright, so ill have to eliminate EGR too, thats what i wanted to make sure of. so basically i have EGR deleted out, and then plug that line and everythign else can stay? i only need the first "EGR Intake kit" right?
thanks for the help, its really making sense now
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
