is this article accurate?
Old Jun 24, 2003 | 03:10 PM
94formulabz's Avatar
http://sethirdgen.org/egr.htm
If so, how many degrees does the timing advance when the PCM activates the EGR?
What RPMS and throttle conditions does the EGR open?
If you block off the EGR is it correct to pull a little bit of timing to compesate for it being blocked?
I also have a post in the computer section but that doesn't seem to get very much traffic and I thought someone helpfull might see this in lt1 tech.
thanks in advance.
-Brent
93 RedBird
Nov 15, 2015 08:24 AM
mark0006
Sep 14, 2015 12:35 PM
cmsmith
Aug 25, 2015 09:42 AM
mark0006
Aug 22, 2015 07:23 PM
4586
Aug 13, 2015 10:11 PM
