ARP thread sealer & assembly lubricant
Old Jan 12, 2004 | 09:04 PM
ibanez6rg's Avatar
Where can I pick up some ARP sealer and lubricant for my heads?
Also which bolts do you use each on (head bolts)? I know whatever bolts touch coolant get sealer and the others get lubricant. But which bolts touch coolant and which ones don't?
Old Jan 12, 2004 | 09:13 PM
AsianSensation's Avatar
I used thread sealant on all bolts and put oil under the head of each bolt. Permatex thread sealer from AutoZone.
Old Jan 12, 2004 | 09:15 PM
ibanez6rg's Avatar
Why did you put oil under the head of each bolt? And did you use the washers that came along with the ARP kit?
Old Jan 12, 2004 | 09:18 PM
gb95zconv's Avatar
Old Jan 12, 2004 | 09:20 PM
I put oil under each head to give a more smooth consistant torquing even though the ARP bolts came quite *greasy*. Yes, I did use the washers because the heads are aluminum. Although the stocker didn't use washers. But hey, what is it gonna hurt?
Old Jan 12, 2004 | 09:33 PM
Oh...and one more thing. There's 3 different head bolt lengths. I'd highly suggest you keep up with which one goes where.
But like most people, they don't pay attention during the disassembly.
So, short bolts (see Chilton for head bolt numbers/sequence),
16, 12, 8, 4, 3, 7, 11, 15
Medium bolts.
14, 17
Long bolts,
15, 5, 2, 10, 9, 1, 6
There's a total of 17 head bolts per head.
Old Jan 12, 2004 | 09:53 PM
Brandon 95 Z28's Avatar
Haha, I was just thinking I have no idea which places i pulled the different size head bolts from. I am just going to use the gm thread sealer on all of my ARP head bolts.
Brandon
Old Jan 16, 2004 | 07:24 AM
ibanez6rg's Avatar
Medium bolts.
14, 17
Long bolts,
Yulp, I did pay attention to that.
Old Jan 16, 2004 | 09:50 AM
30thannZ28's Avatar
wow this is good info, I'm putting my heads on in a couple days. thanks!
Double aught
Oct 2, 2015 11:29 PM
Formula Steve
Sep 19, 2015 08:48 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Dams76
Aug 20, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
