ARP Thread Sealant FTL
Old Jul 19, 2007 | 12:21 PM
Demus's Avatar
So what has everyone been using instead of ARP thread sealant for the ARP head studs?
Old Jul 19, 2007 | 12:27 PM
MEAN LT1's Avatar
Damn son, I havent heard too many bad things about arp thread sealant. Could it have been applied wrong?
Old Jul 19, 2007 | 12:32 PM
Javier97Z28's Avatar
Moderator
I've heard multiple complaints about the ARP thread sealant.
I'm not running studs but the Permatex stuff has been just fine for me.
Old Jul 19, 2007 | 12:54 PM
SStrokerAce's Avatar
I've never had that happen.... how did you install the studs?
Old Jul 19, 2007 | 12:57 PM
speed_demon24's Avatar
ARP thread sealent was letting oil through my rocker arm studs, and it was non-existent on my head bolts when I pulled them out so I have no doubt it was letting coolant into my oil, so you are not alone.
Old Jul 19, 2007 | 01:28 PM
gex598's Avatar
I had problems with studs leaking and the permatex stuff, switched to the ARP stuff and have not had a problem since.
Old Jul 19, 2007 | 08:40 PM
FlamingChicken's Avatar
I just went to the parts store and bought some stuff with teflon. believe it was permatex but not 100%. worked good though for the ~1000 miles the motor was running
Old Jul 20, 2007 | 10:01 AM
Demus's Avatar
Lots of thread sealant and finger tight. Exactly like the instructions say. There's not really much you can do wrong...
Old Jul 20, 2007 | 02:21 PM
bdc95ta's Avatar
Go to ARP's website. Your supposed to screw them all in 3-5times before hand. Also get a coolant pressure tester thing at Autozone, you can rent them for like $80, but you get it back when you drop it off.
-b
Old Jul 22, 2007 | 07:58 AM
JP95ZM6's Avatar
I use Permatex Teflon. I like to run the bolt in and out once with sealer, apply again, and final assemble. Sealer gets down further in the mating threads that way. Also, when applying the sealer, press hard enough with your finger to fill the roots of the threads all the way. You don't need a lot, just enough to fill all the threads to the top. More just makes a mess.
Old Jul 23, 2007 | 02:07 PM
Well if you don't TQ the bolts/studs right after you install them they leak like crazy.
Bret
magman
Apr 15, 2016 03:08 AM
n2oblkz
Oct 22, 2015 02:31 PM
Double aught
Oct 2, 2015 11:29 PM
Formula Steve
Sep 19, 2015 08:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
