ARP Studs for Splayed Caps Ltx?
Old Feb 9, 2009 | 01:27 AM
Meen95z's Avatar
Question ARP Studs for Splayed Caps Ltx?
Im building a ltx with splayed billet caps, I have a Canton Oil Pan and will not be using stock windage tray. Does anyone have the part numbers for the ARP bolts/studs I need?
Old Feb 9, 2009 | 07:32 AM
user 647483's Avatar
ARP 134-5601 http://store.summitracing.com/partde...1&autoview=sku
Main Studs, 4-Bolt Main, Large Journal, Chevy, Small Block, Kit
Designed to fit large journal crankshafts. (No Windage Tray)
Fits LT1 and LT4 engines.
Old Feb 9, 2009 | 03:24 PM
Meen95z's Avatar
now does those have the bolts on the outer, due the angled caps? studs wont work on all 4 on splayed caps?
Old Feb 9, 2009 | 03:29 PM
MikeGyver's Avatar
Maybe the 2 splayed studs are installed in the block after the cap is set..?
Old Feb 9, 2009 | 04:57 PM
dr97z's Avatar
No, just the two inners are studs, the outer two are bolts.
Old Feb 9, 2009 | 08:35 PM
Meen95z's Avatar
well they have a set for splayed caps. They are for splayed caps with straps or splayed caps with windage tray? What ones do I get? I have neither straps or windage tray.
Old Feb 9, 2009 | 09:41 PM
Should be the same bolt set either way. (splayed or not)
Studs for inners, bolts on the outers.
I did mine a few months back.
Old Feb 18, 2009 | 09:33 PM
walt355's Avatar
my set came with all studs, the outer 2 are installed after the cap is in place
Formula Steve
Sep 19, 2023 08:31 AM
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
