ARP Stud Part Numbers??
Old May 31, 2006 | 05:33 PM
SevenStars's Avatar
I've been looking but I havent been able to find them... Can some one get me the part numbers for ARP Main and head studs for my LT1... Its a 2 bolt main with the stock oil pan and heads if that helps.
Old May 31, 2006 | 06:31 PM
GetaZforgetGT's Avatar
Re: ARP Stud Part Numbers??
If you do a search for ARP main studs you will get as much info as you can handle.
ARP-234-5501 is the part number for the two bolt main studs that allow you to run your windage tray.
I think the head studs are ARP-134-4001.
Another good way to find the info is to check out a couple of the supporting vendors websites and see if they have a listing for it. Normally there stock numbers are pretty close to the manufactures number.
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
