ARP intake manifold bolts... Which SBC kit do i get?
Old Jan 4, 2006 | 09:42 AM
sabre81's Avatar
I need to replace these crappy stock rusty bolts, and i was thinking ARP of course. I was looking on summit but i'm not sure which one to pick out of the bunch..
Anyone know? Also, will they have the two studs like the stock bolts?(for the coolant tube, & alternator bracket.
Old Jan 4, 2006 | 10:02 AM
FastZinTennessee's Avatar
Re: ARP intake manifold bolts... Which SBC kit do i get?
I was thinking about doing the same thing, because I've removed a lot of stuff around the intake manifold, and the factory studded ones make it that much more difficult to remove the manifold in the car. I don't know for sure but I'd get the standard small block ones (not the TPI), should have the same thread and all that stuff. It's probably not going to have studs, so you'd have to re-use some of your existing bolts, which kind of defeats your whole purpose. I'd just stick with what you've got.
Old Jan 4, 2006 | 10:53 AM
SStrokerAce's Avatar
www.alloyboltz.com
They have a full stainless bolt kit for a LT1 for around $40 total.
Bret
Old Jan 4, 2006 | 12:52 PM
sabre81's Avatar
Originally Posted by SStrokerAce
www.alloyboltz.com
Bret
Those look nice, but their kit is allen head type bolts. Wouldn't 6 or 12 point bolts be better?
Old Jan 4, 2006 | 12:56 PM
It's only 35 ft lbs on the intake bolts....
Old Jan 4, 2006 | 01:00 PM
sabre81's Avatar
Hmm thats also true. I also found this... http://www.boltlocker.com/LT-1HexandSocket.html
Seem to be pretty similar, i'll probably go with alloyboltz since your the 3rd or fourth person to suggest those.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
