ARP Head bolt torque specs
Old May 24, 2008 | 02:29 PM
Jazsun's Avatar
Bought mine used and don't know what the final torque spec is suppose to be...I have heard 65 ft/lbs but I want to confirm. I intend on using Permatex high temp thread sealant and 10w-30 on the heads.
Also when doing the 3 stage torque process, can I get all the bolts down to the point where are like 1 cm from touching the head using a regular wrench, then start the 3 torque sequence? Or is the 3 stage sequence started right when you begin? Seems like it would take forever.
Old May 24, 2008 | 03:04 PM
Jazsun's Avatar
I guess I am gona go w/ 25,45,65
Old May 24, 2008 | 03:08 PM
z28maro's Avatar
did mine 65 like it says and its been fine so far
Old May 24, 2008 | 03:36 PM
You snug all the bolts down in sequence, then start your torque sequence.
Old May 24, 2008 | 05:00 PM
rskrause's Avatar
Moderator
Very useful chart.
http://www.arp-bolts.com/Catalog/Cat...talog_0024.jpg
Rich
Old May 24, 2008 | 05:30 PM
94zgreenmachine's Avatar
Nice chart ,Rich.
Just make sure you look at the torque specs . They are different depending upon what you use. ARP moly vs. SAE 30. That chart shows the difference in torque specs.
Old May 24, 2008 | 05:35 PM
Jazsun's Avatar
Originally Posted by 94zgreenmachine
Nice chart ,Rich.
Well I dont know what the tensil stength is, and I think the bolts are 7/16's right? That means 80ft/lbs? Somethings not right. I don't think that chart takes in consideration aluminum heads either.
Old May 24, 2008 | 07:14 PM
rskrause's Avatar
Moderator
The specs are fastener specific and would not vary with the type of head. Use the 170-180,000psi column for head bolts or studs. The more exotic (stronger) materials are used for rod bolts, in general.
Rich
Old May 24, 2008 | 08:10 PM
1963SS's Avatar
I just tightened mine three days ago. ARP says 75 ft/lbs if using 30 weight oil and 65 ft/lbs if using their moly assembly lube. I used ARP teflon thread sealer and went to 70 ft/lbs. The instructions gave no option for the teflon stuff.
Old May 24, 2008 | 11:33 PM
Jazsun's Avatar
Well I initially went to 65, then went back over and up to 75. That chart suggest 80.
Old May 25, 2008 | 12:00 AM
Stl94LT1's Avatar
I did 70 lb/ft on the top bolts and 65 on the bottom row.
Old May 25, 2008 | 11:38 AM
OBE1 95Z28's Avatar
Proper lubing of the bolts is more than just thread sealant on the threads, it's also lubing the washer and bottom of the bolt head. If these are dry, it will cause more friction to torque the bolt giving you a false torque reading.
Old May 25, 2008 | 01:17 PM
Jazsun's Avatar
Which is why I used motor oil......
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
