ARP 134-1802 Oil pan bolt kit
Old May 7, 2012 | 07:12 PM
Ricardo's Avatar
Anybody has used this kit on an LT1 application?
ARP states this kit is for the SB with 1 piece rubber oil pan gasket.
No information regarding length of the bolts themselves.
1/2" bolts are a tad too short.
I would like to know if these are at least .625" long
Thanks for any input
Old May 7, 2012 | 07:37 PM
Kevin Blown 95 TA's Avatar
Re: ARP 134-1802 Oil pan bolt kit
I used the stainless studs instead. They made it a lot easier to line up gaskets and I also have a scraper plate in there all sandwiched together.
Old May 7, 2012 | 07:48 PM
Ricardo's Avatar
Thanks Kev.
Those shure look nice.
Do you remember the PN for them?
I would like to use bolts, but might end ordering these.
Old May 8, 2012 | 09:18 AM
I think it was ARP 434-1901 - ARP Oil Pan Stud Kits - they were about $64, but you can get regular non-stainless for about $21 or so - multiple vendors to choose from, too. Just do a search for oil pan studs on Summit then sort on Chevy and they will pop up.
Old May 8, 2012 | 06:58 PM
Ricardo's Avatar
I emailed ARP and was given the following answer. Just in case somebody else runs into this.
Hi Ricardo
Kit # 134-1802 = 14-pcs 1/4-20 x .625 long & 4-pcs 5/16-18 x .750 long.
RonF
According to this info it should fit fine.
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
