Areomotive A1000 and stock fpr?
Old Jul 31, 2006 | 02:04 PM
Boostwhat's Avatar
What would happen to my stock/slp fpr if I plumbed a 1/2" fuel line w/sumped tank and A1000 front to rear and used my stock feed line as a return? Would I destroy it? Derek
Old Jul 31, 2006 | 02:58 PM
cause4panic's Avatar
Re: Areomotive A1000 and stock fpr?
I got a a1000 running on 3/8 line and a stock fpr. no problems so far
Old Aug 1, 2006 | 05:53 AM
Guest47904's Avatar
Guest
It will work fine but understand the requirements of the pump before you start so you don't destroy it like it did mine. Mine came without instructions and the J@#K at Summit told me to put a 40 micron (small frame filter no less) on the input. As you may know the input should never be less than 100 microns.
I had Aeromotive rebuild the pump and plumbed it correctly and been fine since. The only difference between mine and yours is both my lines were replaced with braided hoses.
One last thing, I didn't get the electronic controller. I recommend you understand why you may or may not need one. I was told it was not absolutely necessary. In your application, it may be needed. READ, READ, READ before you start. Call them if you have questions too.
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
HectorM52
Jan 31, 2015 07:29 PM
