Arching at coil??? 93 Z28
Old Aug 14, 2010 | 08:56 PM
Rugermk2's Avatar
Hi everyone,
I opened the hood last night, and noticed that my coil wire was arching to a radiator hose. I moved the wire a little and taped it up. Now the coil itself is arching to the metal housing around it. Why in the world is it doing that? I had the opti itself replaced, the cap and rotor are msd, the plugs and wires are AC delco, and the coil is a msd streetfire. All that and the water pump were just replaced a couple months ago. HELP please!!!!It's my daily driver!!!Thank you for viewing
Old Aug 14, 2010 | 09:23 PM
brubaker's Avatar
High resistance in the seconday ingnition, Wth having the msd coil I would upgrade the wires to something a little better like msd or summit brand. or put a stock coil back into it and replace your coil wire again.
Old Aug 15, 2010 | 04:10 PM
BlackJet385's Avatar
i moved my coils to a bottom mount behind the air damn...and when it rains or lots of moisture, they arch and i get a spuddering in the motor...try spraying them with wd40...that has fixed my arching evertime =)
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
maybe2fast
Feb 5, 2015 05:14 AM
redleader
Jan 22, 2015 12:05 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
