Apexi Air/Fuel Controller
Old Jul 14, 2004 | 03:16 AM
Heatmaker's Avatar
Advanced Member
Can those Apexi AFC fuel and air controllers work on our cars?
ONE OF THESE
Old Jul 14, 2004 | 03:51 AM
jtk's Avatar
jtk
yes, cant see why not
Old Jul 14, 2004 | 09:48 AM
Heatmaker's Avatar
Advanced Member
Old Jul 14, 2004 | 04:21 PM
Heatmaker's Avatar
Advanced Member
Anyone else have an opinion... ideas welcomed...
1. Yes so far...
These devices look to be quite handy since thy show an actual fuel curve... with the rich and lean spots ....
Old Jul 14, 2004 | 05:18 PM
UNIVERSAL FOR ALL JAPANESE CARS. We are selling brand new items, no exchange and refund, Please follow the INSTRUCTION MANUAL and WIRING DIAGRAM.
You might want to ask if it is compatible with an MAF that has a variable frequency output signal. Not all MAF's are like the GM 4th Gen sensor... some are variable voltage output, like the 3rd Gen MAF sensors.
You can only open the instruction manual and wiring diagram if you have the "Japanse Language Package", so its not possible to even look at what they are selling.
Not sure where you get that it will graph "actual fuel curve".... it appears to be able to show the 12-step % adjustments as a graph, which will not tell you much of anything.
Are you aware that Ramchargers sells the "MAF Translator" to specifically alter the MAF output curve of the stock GM 4th Gen MAF? Are you aware that Granatelli now sells an MAF calibrator? Are you aware that none of these is a susbitute for a simple mail order "tune"?
Good luck.
Old Jul 14, 2004 | 05:31 PM
Heatmaker's Avatar
Advanced Member
Good luck.
Interesing Sir... you have rasied my eyebrows...
I have seen these in use .. and they did apear to have a pretty acurate fuel curve...
thought it would be nice to have in the Z
just want to get a tap on the Fuel situation... so I know everything is where it needs to be.
Old Jul 15, 2004 | 02:53 PM
jtk's Avatar
jtk
hmm.. I'm not sure now if the AFC can work with the maf. try and check with some turbo mistu people, those cars also have a variable frequency MAF
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
drt
Sep 27, 2015 04:39 PM
