Anyone using Freescan??
Old Aug 16, 2003 | 02:53 PM
Fastbird93's Avatar
Just wondering. I can't get it to work unless I do the "force data" option, and it's only a one time thing. Shouldn't it be a continually running setup like Datamaster??
Old Aug 16, 2003 | 02:58 PM
whitehooptie's Avatar
I use Freescan. Make sure that you are not charging your computer when you are scanning or programming or reading. It will cause problems. You will have to force data but it should work fine. Make sure you have a good ground on that cable.
Old Aug 16, 2003 | 04:07 PM
transamtom's Avatar
I just hit start then force data and get a continous data stream.
Old Aug 16, 2003 | 05:16 PM
Fastbird93's Avatar
I don't get the continuous data stream, only a momentary data bit when I hit force data. It's no biggie, I also have Datamaster, but I kinda liked Freescan's easier more user friendly setup since I'm a newbie to hooking up to the car.
Old Aug 16, 2003 | 05:33 PM
mike95z28
Guest
Posts: n/a
Sounds like a configuration problem. What kind of car are you using it in? It works only with OBD-I. Set it to 'interact' mode. Not 'listen'.
Old Aug 16, 2003 | 05:38 PM
Fastbird93's Avatar
It's a 93 Trans Am. You don't get more OBD1 than that.
Like I said, Datamaster runs fine. Freescan doesn't for some reason. I'll keep messing with it.
Old Aug 16, 2003 | 05:53 PM
transamtom's Avatar
I think the reason its not working is that its meant to work with 94 and 95 flash program computers,where the 93 still has a chip.
Old Aug 16, 2003 | 05:59 PM
Fastbird93's Avatar
Well, straight from the guys website it says for 92-93 F-Car, and I've heard of a couple speed density guys using it no problems.
Old Aug 16, 2003 | 06:22 PM
transamtom's Avatar
Oooopps,I just checked my version and it lists 92-93 on the line below mine
Old Aug 16, 2003 | 06:33 PM
Farc's Avatar
Hey Guys,
Can any of you say what do this soft and what is need to make it work cable,laptop,ect.
I have a 93Z and I think the only way we have is the pcmforless.
Thanks.
Old Aug 16, 2003 | 06:54 PM
Fbody1's Avatar
I have freescan and it works fine on my car 94z , but on my freinds car it does the same thing that you are saying ( he has a 93 z)I have had to repeatedly push the force data buttonand get the info out of it (but it takes two people one to drive one to run the pc)
timmy39120
May 2, 2015 05:12 PM
DarkHorse
Apr 8, 2003 05:47 PM
Blk94Z28LT1
Mar 15, 2003 11:02 PM
JeffK95Z
Nov 13, 2002 12:50 AM
Dave 96TA
Sep 24, 2002 04:10 PM
