Anyone used the ypipe from summit for the hooker LT's?
Old Jun 18, 2003 | 12:23 AM
Z-OwNEr's Avatar
Curious on fit for:
STW-CA937HKA Y Pipe, Offroad No-Cat., Camaro/Firebird LT1 1993-97 w/Hooker Full Length, Alum.
Dont feel like paying 400+ local to get a custom one and heard the mufflex hangs a bit low. Just curious on this alternative.
Old Jun 18, 2003 | 12:36 AM
HoneyCombs's Avatar
I don't know what your capable of, but I went with the hooker lt's and went with an x-pipe setup that was very easy If you are worried about clearance, I bent the floor boards up that hang low, and it gave me some more space. Good luck with whatever you do
Matt
Old Jun 18, 2003 | 01:12 AM
Cmr0z28's Avatar
the hedman X pipe from summit is cheaper than that Y pipe, then get some dynomax's with dumps right after the X pipe, it will be much cheaper than a Y pipe and cat-back. as far as i know the X pipe from summit fits with no problems at all.
Old Jun 18, 2003 | 02:17 AM
InjectedSS's Avatar
Re: Anyone used the ypipe from summit for the hooker LT's?
Originally posted by Z-OwNEr
Curious on fit for:
$400 WTF??? dude i got a custom y-pipe made locally with clamps for each end (two for the long tubes, and one going back to the exhaust) so i can unbolt it right out whenever i want and it only cost me $120.. i would prolly get that one out of summit cause all the sh*t i ever ordered from them has been flawless.. but i think you could do much better locally.. you just gotta look around! i had guys telling me that they wouldnt make me one unless i put cats on and that i wasnt going to find anyone to do it otherwise yea neways
Old Jun 18, 2003 | 07:39 AM
CANTONRACER's Avatar
I wonder if that is the y-pipe they copied from me. If it is, it fits well.
Old Jun 18, 2003 | 08:03 AM
Z-OwNEr's Avatar
Im not going with true duals as my sig suggests. I dont want it to be all that loud. I already have the cat back and just need a ypipe. No one has ever used this one?
Old Jun 18, 2003 | 02:16 PM
Perry93TransAm's Avatar
I bought one and a few things were wrong with it, first the flanges that bolt to the header flanges were cocked about an inch, I just cut them with a chopsaw and bolted them in place tacked the y-pipe up inder the car , removed it and welded it back up (actually brazed that alumnized pipe is hard to weld with a stick...lol). The y at the back was 3 inch in and 3 inch out and clears easily my BMR DS safety loop. As far as modding my car and clearance, the only issue was the drivers side tranny crossmember needed a little grinding and I dinged the y-pipe to clear the bolt heads, everywhere else it clears nicely and sets up under it better than the mufflex on my 93 T/A.
RUENUF
Mar 13, 2016 03:37 PM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
Slayer
Aug 17, 2015 03:55 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Devinfoote87
Jul 30, 2015 09:54 AM
