Anyone use FLPs on 96-97
Old Jan 10, 2004 | 08:16 PM
badazzcamaro97's Avatar
I was wondering if anyone has the FLP longtube headers on a 96-97. I see Thunder racing has a set up with cats and y.Is there any mods needed for 96-97, because I noticed the AS&Ms reguire a check valve adapter. Does this also go for the FLPs?
Old Jan 11, 2004 | 12:52 AM
AsianSensation's Avatar
The FLPs are a direct bolt-on and needs no modifications. The only "mods" I would suggest is chunking the supplied header bolts and gaskets for some ARPs header bolts and Fel-Pro 1406 header gaskets. Been good to me so far.
Old Jan 11, 2004 | 09:17 AM
Okay. Thanks for the info. Looks Ill be getting the FLPs then.
Old Jan 11, 2004 | 12:35 PM
SlickBlack Z's Avatar
FLP makes a great header system...I installed mine about 6 months ago and I love them. Just be aware that your computer will most likely set off a p0400 code due to lack of backpressure going to the EGR valve. It drove me nuts until I made an EGR simulator...and now the light doesnt come on anymore. If you need info on how to make one...email me and I'll help you out.
Old Jan 11, 2004 | 05:02 PM
96ZRide's Avatar
I'd highly recommend urethane motor and tranny mounts to prevent the motor from twisting the driver's side y-pipe up into the chassis.
Old Jan 13, 2004 | 08:39 AM
I was planning on changing the motor mounts but I didnt even think about the tranny,thanks for the info
GREEN3112
Feb 10, 2019 09:19 PM
Ringmaster72
Dec 12, 2017 10:12 PM
vmax1500
Sep 9, 2002 04:14 PM
KmartZ
Aug 27, 2002 11:42 PM
kazman
Middle Atlantic
Aug 23, 2002 04:38 PM
