Anyone use conventional oil in their high mileage lt1?
Old May 30, 2003 | 10:54 AM
  #16
Patman's Avatar
Originally posted by SweetZRag
By the way, I have had to replace the Opti twice (about every 100K miles) and it is a piece of junk. Chevy traded a throw away rotor and cap for a throw away distributor.
Replacing a $200 part once every 100,000 miles isn't exactly all that bad if you think about it. I'm still on my original opti at 85k. If I have to replace it every 100k I'm not all that concerned.
Old May 30, 2003 | 11:05 AM
  #17
SweetZRag's Avatar
If you are doing the work yourself like you and I, you are right. Think of the poor slobs who are paying the dealer for this work like I did the first time. Cost me $1500 and a week in the shop because they couldn't figure it out.
Now you are comparing $1500 against the cost of a rotor and cap every couple of years. Suddenly it doesn't look like a good design change.
When you are mechanically inclined like most of the people on this board, you don't always see thinkgs like the most people who are payng a mechanic. It's times like this I thank my dad for showing me stuff!
Old May 30, 2003 | 11:15 AM
  #18
Fastbird93's Avatar
I started using Valvoline Max Life about 4000 miles ago, and have noticed that less oil leaks now, and the car really seems to like it.
Old May 30, 2003 | 11:30 AM
  #19
Joe Brodman's Avatar
GP Moderator
I've yet to be sold on synthetic oil. If something in my shortblock breaks, it sure as hell won't be because I was using conventional oil.
Old May 30, 2003 | 11:33 AM
  #20
jpolz's Avatar
Hey Joe, Did you ever find out where your oil was leaking from?
Old May 30, 2003 | 03:57 PM
  #21
Phatcaprice's Avatar
Synthetic or not, a bad gasket or seal, is just that. Say your leaking less with Synthetic, is it really worth it to keep buying that expensive *** oil, than to just replace the worn gasket? Don't know about your area, but regular oil here is $1.89 +/- 10 cents, synthetic is like a buck extra usually, i'd rather fix the gasket problem. Like Joe Brodman, I'm not sold on synthetic yet. Especially after seeing sprint car guys go 2 seasons on a 800hp NA motor, with Penzoil.
Old May 30, 2003 | 04:30 PM
  #22
GREGG 97Z's Avatar
When everyone mentions how lots of high hp race cars run conventional oil with no problems I kind of assume that those guys also change their oil after every race anyway??? If thats the case it probably wouldn't make much of a difference for them to use synthetic if they're going to change it for every race. For people that run their street cars hard and go 3-5k between changes I think synthetic is a better idea.
Old May 30, 2003 | 05:19 PM
  #23
Mkay, you got me there. I just don't think bearing failures having any direct relation to oil type. There are motors that last 300,000mi on conventional, some go at 20,000mi. The same goes for synthetic oils. I think it really depends on the owner, tune-up schedules and how they drive their car. If anyone is that worried about it, and your car was built on a friday, go for it!
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
