Anyone use conventional oil in their high mileage lt1?
Old May 29, 2003 | 08:14 PM
sabre81's Avatar
Anyone use conventional oil in their high mileage lt1 with no problems? And what do you use?
thanks
Old May 29, 2003 | 08:21 PM
Timberwolf's Avatar
I did up til the last oil change and had no problems. Then I ran half a can of seafoam through the crankcase and oiling system for about 50 miles ebfore changing the oil and switching to a thicker synthetic.
Old May 29, 2003 | 08:22 PM
12SCNDZ's Avatar
Pennzoil 10w30 @ 94,000 miles. Does it like it?...It went 12.82 last year with a completely stock motor.
Frank
Old May 29, 2003 | 09:14 PM
Mike94ZLT1's Avatar
Pennzoil 5W30 in mine, runs like a raped ape with 115,--- on the clock. Doesn't burn a drop of oil, might leave a teeny tiny spot of oil on the driveway once in awhile, but I'm not concerned with it.
Old May 29, 2003 | 09:20 PM
2MCHPSI's Avatar
Actually high mileage motors might not like synthetic oil. The molecules in synthetic oil are smaller, and might cause oil consumption passing by the rings on a engine with high mileage.
So if you use synthetic and notice oil consumption, then swith back.
I never have used synthetic oil and got 370k on my last buick 3800
Old May 29, 2003 | 09:32 PM
fastcamz28's Avatar
I use Castrol 10/50 in my z28 that has approx 208,000 miles. Bottom end is original. No leaks, no consumption, still runs like new!
Old May 29, 2003 | 10:18 PM
z28jaz's Avatar
I'm running Valvoline Max-Life 5w 30. The car has 98k on it. No leaks or oil consumption.
Old May 30, 2003 | 03:45 AM
unTAmedLS1's Avatar
IM running 10w30 Mobil1 Synthetic on my 94000 mile LT1. No leaks and goes low 12s on stock bottom end.
Old May 30, 2003 | 04:57 AM
Derrick Redd's Avatar
Old May 30, 2003 | 05:53 AM
mc63's Avatar
Pennzoil here 5W30 every 5,000 miles with 148,000 miles and does not burn a drop.
Original Opti Too!!!
Old May 30, 2003 | 08:03 AM
Phatcaprice's Avatar
Napa oil, on every car I've ever had, all with high miles, never an internal engine failure. I wonder if all these spun bearings everyone is having on this board is related to synthetic oil?
Old May 30, 2003 | 08:27 AM
chasmanz28's Avatar
Originally posted by FlyBono24
Another vote for Max Life...
If you have high miles, especially over 80k, I'd definitely recommend it!
yeah but max life cost as much per quart as mobil 1 syn does. i can see if it was cheaper
Old May 30, 2003 | 08:45 AM
Patman's Avatar
Probably not. If you use a good 5w30 synthetic for instance, it remains a 5w30 for well over 5000 miles or more. Put a 5w30 dino oil into your engine and it'll turn into a 10w20 oil in less than 2000 miles. Which of those two do you think will protect your bearings under hard use?
Conventional oils can get long life out of normal vehicles, but IMO, if you're going to drive it hard, and especially if you're going to drive in extreme cold, you'll get longer engine life with synthetics. (or with a good blend like Schaeffer Oil)
Old May 30, 2003 | 10:18 AM
TransAm219's Avatar
Quaker State synthetic blend for High Horsepower Engines
10w30 in the Summer
5 w 30 in the Winter
No internal problems @ 115k
Old May 30, 2003 | 10:28 AM
SweetZRag's Avatar
I thought you asked for high mileage cars . I've got 230K miles and I used nothing but Valvoline 5W-30 since day one every 3,000 miles. I recently had to replace the cam shaft and lifters because one of the rollers developed a chip in the roller surface. The engine looks like new inside with no wear or sludge. I love Valvoline! I also have a 94 Blazer with 190K miles and it is in the same condition.
I have friend who works for Mobil and knows the chemists who developed Mobil 1. He says he uses nothing else and that Mobil 1 is the best. I don't see the benefit for the extra cost.
By the way, I have had to replace the Opti twice (about every 100K miles) and it is a piece of junk. Chevy traded a throw away rotor and cap for a throw away distributor.
