anyone smog their LT1 on the new CA smog2?
Old Dec 13, 2003 | 01:34 AM
mineralwater's Avatar
Question anyone smog their LT1 on the new CA smog2?
Just wondering how many of you guys passed/failed your LT1s on the new CA's "rolling dyno" smog?
Reason being, I have to smog the 1994 z28 soon. its got no egr pipe and no cat, but I am having midas/meineke weld one on this monday. Motor is otherwise stock.
I am praying that I pass smog! I can't afford to fail.
How much stricter is the new smog? I'd love to hear pass/fail stories and feedback.
P.S - CA sucks!
Old Dec 13, 2003 | 02:49 AM
93formula's Avatar
on a stock car i think youd want the egr to work and the cat as well other wise you should be fine. im guessing anyway. we have roller tests in my area. as long as the emmisions equipment is there on a stock car you shoudl be fine.
Old Dec 13, 2003 | 03:57 AM
BlackLT1_TX's Avatar
In Dallas we have had the rolling sniffer. I always thought the CA Smog ****'s were worse then here in Texas. Seems like they are twins.
TXDOT sucks!
Old Dec 13, 2003 | 06:18 AM
Fuels94TA's Avatar
I would put all things back on. As for 94 in CA they are know as smog polluters. Is your upcoming test a smog test, or test only? If you get a renew notice with test only you have been put on the hit list. I was on the test only and pass by one point away from failing.
Vinny
Old Dec 13, 2003 | 05:43 PM
RedPhenx's Avatar
what is 'rolling smog test'?
Old Dec 13, 2003 | 05:45 PM
Robert95z's Avatar
your car is on a dyno with the sniffer stuck up your tail pipe
Old Dec 13, 2003 | 06:37 PM
Larnach's Avatar
Time to wire up an auxillary air pump to a line just before the cat.
Old Dec 13, 2003 | 07:03 PM
95_LT1_6SPD's Avatar
maybe if you fail they will tell you how much power you make just so your happy
Old Dec 13, 2003 | 07:08 PM
Larnach's Avatar
If only it were that kind of dyno.
Tell the, "NO, I know it will pass, just a few more runs ok?"
Old Dec 13, 2003 | 07:10 PM
Robert95z's Avatar
actually it is the same kind of dyno, only thing is different is the software.. i work at a place that does inpections, he said all you have to do is buy the $5,000 software or maybe it was $500 i dont remember
-Robert
Old Dec 14, 2003 | 03:26 PM
Bud M's Avatar
My car blows through smog check no problem. If you have a good cat and everything else is working right you should be fine.
Old Dec 14, 2003 | 07:05 PM
EDS Z28's Avatar
I passed by a mile. It seems every time I have to go for smog, the limits on HC & NOX get more stringent. It doesn't make any sense at all, those limit numbers should get greater over time, not less. Everything should be hooked up, especially the egr w/ a stock cam. With the hotcam, you don't even need the egr to pass.
JUst a note about making your cat converter last longer. Have the a.i.r. hooked up and do not run the engine in open loop. I did and it fried the converter after awhile. You will most likely fail without the converter on the car.
Old Dec 14, 2003 | 11:10 PM
thanks for all the tips, guys. makes me feel a bit better about smogging this tuesday. I'll keep you guys posted
Damn CA smog *****!
Old Dec 15, 2003 | 12:11 AM
MentalCaseOne's Avatar
Mine passed it twice before I moved to Hawaii. You will need the EGR fer sure. Those grease monkeys check for it.
Put everything that needs to be there and you will pass if your engine is running good.
is your cam stock? Mine is.
Marvin
Old Dec 15, 2003 | 10:52 AM
SS MPSTR's Avatar
Killa Kali.
cheapchevy
Apr 8, 2015 08:48 PM
alphaauto
Jan 23, 2015 07:42 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
deadmanrunning
Jan 3, 2015 01:12 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
