Anyone running unported LT4s w/medium cam?
Old Oct 8, 2003 | 12:12 AM
97bowtie's Avatar
As the subject says, is anyone running untouched LT4 heads w/a meduim hyd. roller? By medium, I mean XE 224/236, CC306ish etc. Anyone have any dyno/track numbers with a setup like this?
Thanks.
Old Oct 8, 2003 | 12:20 AM
S.J.S.'s Avatar
Not to be off subject or anything but damn dude. You run 12.60's with just those mods????
Old Oct 8, 2003 | 12:28 AM
97bowtie's Avatar
Yeah - 12.6 was in the summer. May have some new bests tomorrow night.
Old Oct 8, 2003 | 12:31 AM
HM Murdock's Avatar
I think I fit your requirements, but no, no times or dyno runs yet, she only has 700 on the new motor.
Old Oct 8, 2003 | 12:34 AM
97bowtie's Avatar
Close. I'm looking for stock bottom, stock - 11:1 compression etc. Should have specified. Some dyno/track numbers from your setup would give me a good idea though.
I'm thinking 375-380 rwhp would be attainable w/stock LT4s, medium hyd. roller and a good dyno tune.
Old Oct 8, 2003 | 02:28 AM
Brandon 95 Z28's Avatar
Sorry for the off topic question, but what makes you not want to port them? I know a good LT1 porter in the PHX area, i have to look up where his info is, but he does good work and is very reasonably priced.
Brandon
Old Oct 8, 2003 | 02:35 AM
97bowtie's Avatar
Brandon
Here's my thinking:
I can either port the LT1 castings I have - pay around $1200 for a local port job that may or may not be a good head. Or, I'm thinking of buying LT4s, running them stock for a while - then have them ported by a reputable porter when I build another motor. The LT4s have more potential than the LT1s and I think I can get pretty decent numbers with stock LT4s and a medium cam. It is just a thought.
Send the porter's info my way. 95bowtie@lycos.com
Thanks.
Old Oct 8, 2003 | 02:41 AM
94formulabz's Avatar
383 bottom end (sorry)
UNported LT4's with a mild valve job only
224/236 cam
368 rwhp at the woodbridge dyno (some say it's low, i have no proof of that and kind of doubt it myself).
Track times suck due to an amature driver (my cousin) on street tires. Low 12s though.
Nice tq due to the 383.
We are upgrading to ported AFRs on the 383 and my 350 is getting the LT4's after porting
Personally i would just save up and have them ported right away because then you won't be kicking yourself a week later when you get used to the power. You will also only have to swap heads once which is probably a good thing.
-brent
Old Oct 12, 2003 | 09:40 PM
TCAL95Z's Avatar
97 bowtie,
I do not think you can get that close to 380rwhp with stock LT4's
I know someone who has a decent port job on LT1 heads with the hot cam and a very good dyno tune. With a 6sp car he is at 370rwhp
Brandon,
Who do you know that ports heads in Phoenix?
Do you either of you guys go to the pavillions?
Old Oct 12, 2003 | 11:35 PM
ULOOSE's Avatar
I think its possible,
I know one person with a 97 LT1, Stock LT4 heads, intake, CC305 cam, basic tune, made 360 rwhp..Stock bottom end..
I have a 93, they tend to react a little better to basic mods, I have all the bolt on's, gasket matched LT1 heads, CC305 cam, and I made 356 rwhp with a basic tune, and 342rwhp on a stock tune..
BTW, My car trapped 113 mph back to back on the stock tune in cold weather, ****ty launch and 13.0's to 13.3's all night..
Mph was anywhere from 111 to 113, with no better than a 2.3 60ft time.. this was on the stock tune at 342rwhp..
I deffinetly think it can be done, and I think the MPH for what you have already, making full use of traction is dead on..
Hehe, Ive rambled enough
Old Oct 12, 2003 | 11:53 PM
Z95m6's Avatar
I think 375rwhp would be the high side of hp with that setup. probably about 360rwhp. Maybe there is a formula you can use to figure it out. Marcin made high 340's with his cc306 maybe you can find a formula for the extra hp from extra flow of LT4's.
Old Oct 13, 2003 | 04:03 AM
RedPhenx's Avatar
i think that 348 or so was just with a mail order tune, not dyno tuning.. he should have around 360 now iirc.
Old Oct 13, 2003 | 02:44 PM
Fast Caddie's Avatar
There's a member on this board with an LT4 Firehawk with stock heads and intake/full exhaust mods and rolled 360rwhp on a mustang dyno. Probably 370-380rwhp on a dynojet. Port those boogers good and 430+rwhp should be plenty possible on the stock bottom end.
I don't know if anyone here has tried the max effort LT4/CC306-ish cam route on the stock bottom end. Would be interesting to see. LS1s are hitting 450+ so we won't be too far behind I think.
Old Oct 13, 2003 | 03:19 PM
RealQuick's Avatar
I am using ported LT1's that beat the snot out of unported LT4's (as far as flow numbers are concerned) and I am at 383rwhp with old tune. I am getting a new tune this week and should be hitting the dyno. For 1000 bucks I bought all new valvetrain (2.00/1.56 valves, springs, retainers, seats, etc.) and port work by Lloyd Elliott. Bang for the buck.
LeftoverChinese
Jan 14, 2024 03:03 PM
parkers Z28
Mar 11, 2016 08:14 PM
95chwagon
Jan 13, 2015 09:19 PM
