Anyone running a CC503 on a 114LSA??
Old Jan 19, 2006 | 02:46 PM
roughneck427's Avatar
I did a search and couldnt find such info,if you are running that cam or have how was it from someone running it on a 112LSA??really wanna know if it smooths out the idle by changing the LSA im trying to stay smog legal but want a good choppy when i roll to a stoplight people know i have some heat
Old Jan 19, 2006 | 03:15 PM
madwolf's Avatar
Re: Anyone running a CC503 on a 114LSA??
The idle is smoother on a 114, but there is still some lope. Then again, some people will say a CC503 on a 112's lope isn't really a lope.
If you want to find out how it sounds, look for CC305 files. They sound pretty much the same.
Old Jan 19, 2006 | 03:21 PM
BlackScreaminMachine's Avatar
The same duration and lift number w/ a wider lobe sep = Great for FI, Loss of Torque in the low and mid range rpm for N/A
Old Jan 19, 2006 | 03:23 PM
so you saying with a 112 you will have more low end and mid range???
Old Jan 19, 2006 | 04:11 PM
T/A Racer's Avatar
im running the cc305 right now but its no longer going to be in a 350 anymore due having to rebuild my engine. i could definately notice a nice lope to it but that may have just been because i didnt have a tune on it. thats gettin fixed as we speak. anyways i had fairly open exhaust and you could definately tell it wasnt stock even on the 114 LSA. for my needs it fit well, and that with 1.6rr i could definately tell an increase in top speed, not that most people are very concerned with that but i suppose that means a good hp increase.
Old Jan 19, 2006 | 06:59 PM
1racerdude's Avatar
If ya want it to lope put it on a 108+4 and ya will get max power.
Old Jan 19, 2006 | 07:25 PM
96capricemgr's Avatar
Taking a cam designed to end up with 112 and spreading it to 114 to tame it will result in DISAPOINTMENT. If the 503 is going to be a little to radical on some front then go with a different cam, smaller cams can lope especially if you request it from the tuner.
Old Jan 19, 2006 | 07:36 PM
Yea, a friend of mine has a cam thats as far as duration and lift is concern, it SMASHES my Hotcam, but its at a 114 LSA. This was intended for a blower, but never happend. We have taken his dyno sheets and graphed it. He loses massive amount of torque until after 3500 rpms and then starts to gain. The car has wicked top end pull, but is a dog on the low end. With 2800 stall and 3.23 gears it still is a dog. It needs a blower or 4.10 gears (auto).
http://www.babcox.com/editorial/ar/eb90252.htm
this is a excellent page about cam events. How its wrong to use LSA to make a cam look huge in the duration section, but then to tone it down by a 113,114,116 etc etc LSA
parkers Z28
Mar 11, 2016 08:14 PM
nikolt1
Feb 27, 2015 09:10 PM
camy 1993
Feb 1, 2015 07:16 PM
InfernalVortex
Jan 17, 2015 09:35 AM
