Anyone run straight h2o and water wetter in the summer?
Old Jun 26, 2003 | 10:37 AM
Timberwolf's Avatar
My car has been getting fairly wam lately... thinking of going that route since it should cool much better. Only thing I am worried about is lowering the boiling point too far
thoughts?
Old Jun 26, 2003 | 10:40 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
doing this is a band aid IMHO-
there is a reason why your car is running hot. its not because you have coolant in it. Your car is pretty much stock and we have stout cooling systems. find problem and fix it.
4DRSS's Avatar
I have two years in a row, works great. I just flushed my system last week, still VERY clean, no corrosion.
Old Jun 26, 2003 | 10:45 AM
Timberwolf's Avatar
it's not running very hot, just warmer than I like at speed. Anythingunder 80 and it sits around 180 degrees. above 80 for any length of time (like my daily commute) it goes up to the 220-230 range
I think it is partially becuase of the reduced capacity of the cooling system. Yanked the oil cooler and heater core, plus related hoses...so that's a good gallon gone right there.
But I did pull the a/c condensor reducing air restriction...
Rad is not the greatest anymore, could be part of it... never noticed a problem before, but it hasn't ever been this hot (weather) since I've owned the car
Old Jun 26, 2003 | 10:48 AM
IDOXLR8's Avatar
I usually run two bottles of water wetter with straight water. I have not had any issues to date.
Gripenfelter's Avatar
I have to keep the heat on full in the summer heat to keep the car from over heating.
Since then I've started running 3 bottles of water wetter and 100% water. Stays a lot cooler. Also added 2 pusher fans.
Just bought an aftermarket rad too that needs to be installed.
Old Jun 26, 2003 | 10:53 AM
Rodrigues's Avatar
Why are guys having cooling problems?! My car never goes above the 1/4 mark on the temp gauge, I have tried different sensors (not becausing im running cool) but because I broke them doing heads and headers.
Old Jun 26, 2003 | 10:58 AM
treyZ28's Avatar
Grip-
there is something wrong with the vehicle if you need 2 more pusher fans, pure water, water wetter and a bigger radiator.
Old Jun 26, 2003 | 11:25 AM
IDOXLR8's Avatar
Dam I knew I should had kept my stock radiator. The reason I am having heating issues is because I am running a single 16-in low profile fan. I am going to be buying a pusher fan for the front of my radiator to help deal with this issue.
Old Jun 26, 2003 | 11:33 AM
treyZ28's Avatar
i have a silly feeling things change a bit from a stock car to a 700rwhp superchaged 383
Old Jun 26, 2003 | 11:47 AM
Grip-
The more horsepower you make, the hotter you run.
I was fine until I did the stroker.
I know another guy with a 90 IROC-Z that has the same problem with his stroker.
And yet another guy with an LS1 had the same thing happen after adding a blower.
Old Jun 26, 2003 | 11:51 AM
IDOXLR8's Avatar
Oh yeah I forgot. . The only reason I upgraded to a Be Cool Radiator is because I got a smoking deal on one (300 brand new). With the stock fans and radiator I was not having any type of cooling issues. I should had just kept my stock radiator.
Old Jun 26, 2003 | 12:38 PM
TMDZ28's Avatar
maybe waterpump problem?? mine went out after doing that....
Old Jun 26, 2003 | 12:47 PM
96 WS6's Avatar
I'm with trey, you guys have some weird problems... I can sit in traffic and it RARELY and I mean RARELY goes past the first mark even if I'm sweating like a pig, if I'm cruising it's all gravy, I have a blower too. Adding stuff like that has no effect on the cooling system. Now if you add a blower and you add a heavier foot, the cooling system will obviously pick up more heat on it's track back to the radiator. Or if you added a blower that was lubricated by coolant, then yeah I can understand. But unless you are romping on the gas more, engine mods don't make your car run hotter. I'm using about 50/50 with 1 bottle of water wetter.
Old Jun 26, 2003 | 12:53 PM
Timberwolf's Avatar
I've also been told by many sources ONE OR TWO drops of dish detergent will do the same thing as water wetter.
