Anyone run the lt1 to lt4 conversion?!
Old Jul 7, 2005 | 04:28 PM
  #16
97formulakid's Avatar
Re: Anyone run the lt1 to lt4 conversion?!
I would personally stay away from the LT4 package unless you are going to port the heads and get a different came. THey make good power for what you are doing but for the money you can get a kick *** kit from Lloyd. I know when I do my 383 I am doing a Golen/Lloyd package. Seen very good numbers from that set up.
Just FYI, I recently raced a LT4 converted 96 T/A here last week. With nitrous and MINOR bolt ons I had him by around 2-3 cars. With the LT4 setup you will run with stock to bolt on LS1's. But as stated before, money can be spent wisely somewhere else.
Old Jul 7, 2005 | 04:35 PM
  #17
hallbilly's Avatar
Originally Posted by 30AnvZ28
try and stay away from custom cams... they arent proven performance... they are based on mathmatical statistics... and we all know that engines have a mind of their own... look around, talk to people, find a mass produced cam that has been successful for many people... try the 305 or 306 from comp
So if a custom cam grinders work is "proven" you are saying that it would not be wise to go with that work. Or??
Old Jul 7, 2005 | 04:41 PM
  #18
i wouldnt go with anything else but a custom grind. It is matched to your components and made to run like you want it to. What could be worse than that. Off the shelve grinds are just common cams that have worked for people but you almost have to build your motor around the cam.
Old Jul 7, 2005 | 04:47 PM
  #19
1993Fast_Z's Avatar
Comp will help you out, they ask for all of your specs on your car, what you want it to do, Tranny ratio's, etc., but yea a popular mass production cam is best if you dont know the stats....
Old Jul 7, 2005 | 04:49 PM
  #20
1993Fast_Z's Avatar
yea, but your car was on crack...how big of a shot?
Old Jul 7, 2005 | 05:21 PM
  #21
30AnvZ28's Avatar
if a custom grind cam is proven, thats different... if its not proven and your pulling specs out of your *** thats different... i called comp and they recommended a different cam for me... but then i called a different company, and loved one of their cams... the only thing i decided to do was change the LSA since Im running a n/a motor... dont pull specs out of your ***... read what works... a custom grind cam with no feedback is playing the lottery.
Old Jul 7, 2005 | 05:27 PM
  #22
Originally Posted by alwayscode
Maybe I was thinking the ls1's and vettes had aluminum BLOCKS and we have the cast ones, right?! ...---
All LT1 blocks are cast iron.... C4, F-body and B-Body.
You should review some of the info in here:
http://www.automotiverebuilder.com/ar/ar99928.htm
Old Jul 7, 2005 | 08:38 PM
  #23
Jeremy95TA's Avatar
Correct me if I'm wrong, but stock for stock LT4 heads flow better than LT1 heads. Ported LT1 heads flow better than Stock LT4 heads and Ported LT4 heads flow better than Ported LT1 heads right?
Wouldn't you make more power by switching to the LT4 setup and then porting out the heads and intake and putting in a custom cam?
Old Jul 7, 2005 | 08:39 PM
  #24
30AnvZ28's Avatar
yeah... but ive seen some LT1 heads outflow LT4 heads... both being ported... it all comes down to how much money you want to spend.
Old Jul 7, 2005 | 08:42 PM
  #25
96capricemgr's Avatar
You could but ported LT1 castings are all most 350s need. If going all out then you could look at porting LT4s or aftermarket castings.
Custom cams can be good if put together by a knowledgable person, I think there are a lot more grinders out there than people who know how to spec a truely great custom cam, it is more than lift duration and LSA.
Old Jul 7, 2005 | 08:44 PM
  #26
30AnvZ28's Avatar
dont get a custom cam without researching the specs first... like i said... its like playing the lottery.
Old Jul 7, 2005 | 09:15 PM
  #27
If looking custom it is not the cam you shop for but the expert behind it that is what you have to research.
Old Jul 8, 2005 | 08:12 AM
  #28
1993Fast_Z's Avatar
well, it just depends is the little amount of HP difference with Ported LT4's gonna be worth $1400 for the heads, when you can save about 1400 and get almost the same HP.
Old Jul 8, 2005 | 12:04 PM
  #29
AlwaysCode390's Avatar
What is the LSA (lobe separation angle?) Thanks guys, I really appreciate all your info--
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
