Anyone run this kind of Comp Cams....
Old Jul 5, 2005 | 11:12 AM
FIREHAWK #7's Avatar
anyone run this kind of comp cams roller rocker http://www.compcams.com/Technical/Cu...g/HTML/310.asp when i go to the LT1 sections of Thunder Racing etc... i dont see these there. I only see the PRO MAGNUMS. Can i use these on the LT1????
Old Jul 5, 2005 | 11:31 AM
blackztpi's Avatar
Re: Anyone run this kind of Comp Cams....
those are fine, but they are just a roller tip rocker arm. the best rocker arms are a full roller. they have a roller tip and a roller rocking mechanism...(probably not the best worded for that function)
Old Jul 5, 2005 | 12:00 PM
WS6T3RROR's Avatar
i do believe the word(s) you were looking for was roller trunion.
Old Jul 5, 2005 | 05:14 PM
k thanks guys..... should i expect to see any gains out of this rocker vs the stock stamped steel ones.....
Old Jul 5, 2005 | 05:33 PM
WS6T3RROR's Avatar
i would say it would be minimal. any increase would be from decreased friction, less flex, and a more accurate ratio acrossed the board, and if you go up in ratio you'll have more lift. but honestly the price roller tips go for... just get some cheap cranes or a set of harland sharps that are full roller. probably wont cost you over $50-80 more.
Old Jul 5, 2005 | 09:53 PM
the thing is that i bought these for less then $80.... so i guess i got a good deal. what do ya think?????
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
cmdeshon
Dec 27, 2014 10:06 AM
