Anyone make a bolt on radiator that's better than stock?
Old May 8, 2003 | 03:51 PM
  #46
95 Z/28 LT1's Avatar
Super Moderator
Originally posted by frmula1
certain liquids are only chemically capable of holding a certain temperature.... and they cannot be heated beyond that... for instance if you tried to instantly raise the temperature of a gallon of water from 100 degrees to 300 it would "superboil" water, in its liquid form cannot be raised above the boiling point of 212 degrees F. when it does... it turns into steam... however when its in a sealed enviroment (like your cooling system) with no air present, and unable to expand into a gas because its under pressure... the liquid saturates... and is unable to absorb and more energy or heat because it has reached its tilt...
The "tilt" you speak of is actually called the Critical Temperature. It is the temperature of a substance that above which a liquid state cannot exist. Even with unlimited pressure.
Pure water for example has a critical temp of 374 degrees C, (don't quote me on that though.)
Old May 8, 2003 | 06:22 PM
  #47
FastZinTennessee's Avatar
WOW!!!! I didn't know my thread would turn into such a good discussion. Anyhow, thanks for all the great input from everyone.
Back to the original question, I really don't want to run a lower temp thermostat in my car, I have done some research and understand that stock temperature is more or less optimal for what I'm doing with the car. Even if it's not optimal it's close enough.
My car runs at about 185* normally. However it seems that the stock cooling system on a hot day has trouble keeping it at that. The temp will wander up to about 200-210. I know this is not such a big increase temperature wise, but honestly it feels like a big diference performance wise. I don't know a whole lot about how the PCM responds, but I would not be surprised at all if it pulled timing, and richened the mixture(or opened the EGR valve which I don't have)when the coolant temperature rises.
LT1s hate heat. The last time I raced a 10* ambient temperature killed about 1.5-2mph off of my trap speed.
Pretty much all I'm looking for here is a way to keep my motor at about 185* all the time. City driving, highway driving, traffic jam etc. I will try a manual fan switch, and see how that does. I also think I will get some additive like water wetter and see what good that does. Otherwise I'm open to suggestions!!
John
Old May 8, 2003 | 08:44 PM
  #48
95_RipperZ's Avatar
Originally posted by Rpm280
Thanks goodness! Injuneer to the rescue.
You can thank me for that one. I saw a good discussion here so I hinted for Fred to visit. I like reading this crap.
Old May 10, 2003 | 12:28 AM
  #49
jasons93z's Avatar
Originally posted by treyZ28
I originally thought that too,
but then i thought- that thing is on the sniffer for 30 seconds after sitting for 15 -20 min. how is that helping anything?
Also, after some research if found that the wear rates of the metals were THREE TIMES AS HIGH with a 160 stat.
Where are you getting your research, the tabloids, this JUST in, trey doesnt know anything .
Old May 10, 2003 | 11:11 AM
  #50
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
it was somewhere on this forum actually. When i first joined. guy had a website showing his "test" too.
HectorM52
Jul 30, 2017 11:46 AM
InfernalVortex
Jan 17, 2015 09:35 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Catmaigne
Dec 25, 2014 12:16 PM
