Anyone make a bolt on radiator that's better than stock?
Old May 8, 2003 | 12:38 PM
  #31
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
how does the egr cool????? 200 degree exhuast gases... or 70 degree air from outside....
Old May 8, 2003 | 12:39 PM
  #32
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Originally posted by frmula1
well i don't often like to assume i have as much knowledge as alot of you... but just for the sake of argument i'll throw my ideas out there...
I don't believe that the block being 20 degress cooler/warmer is going to affect the amount of combustion... its a proven fact that a cooler/denser intake charge provides more power... all performace modifications and parts created to allow a cool intake charge are designed to keep in the intake charge as cool as possible... (like keeping the air away from engine heat effieciently) now that air, that we spent all the time trying to keep cool is what is combusting... allong with fuel obviously... so if what your trying to explode is best at its coolest i do not believe there is a difference between engine temp... and intake temp as far as performance goes
now i think its quite possible that gm wanted to engines to run a little hotter for emissions NOT FOR A MORE COMPLETE COMBUSTION.... but an overall higher temperature of exhuast gases.... as we all know cat's don't work until they are up to temperature... which is why i can smell my car running slightly rich when i start it up on these cold new england winter mornings... the hotter the cat = the better the cat works (to a degree, obviously)
my .02
If the coolant is termally "saturated," it wont absorb any of the heat (energy/power). The heat and engery has to go somewhere... and it will go into smashing that piston down faster. I think thts why fred was getting at???
Old May 8, 2003 | 12:41 PM
  #33
treyZ28's Avatar
yeah its 200*, but combustion temps are severl times that.
It displaces air that could burn. so less gas. less gas to burn with same a/f ratio = less engery going in, less coming out(heat)
kind of like making the engine have less displacement. the egr is just dead air, it just takes up space that oxygen would normally combust in
Old May 8, 2003 | 12:45 PM
  #34
frmula1's Avatar
but don't you need that oxygen for a complete combustion?
i thought we blocked off egr for performance in our cars?
if you use antifreeze and not just water like me... the coolant won't saturate until like 300 degrees i believe
Old May 8, 2003 | 12:51 PM
  #35
Trey:
You have to understand that they are trying to control three different pollutants. Two of the pollutants are "oxygen deprived".... unburned hydrocarbons (HC) and carbon monoxide (CO). These form when combustion is not complete. They are probably a lot more sensitive to A/F ratio than to combustion chamber temps. "Rich" makes for HC and CO. They will complete the oxidation reaction better at higher temperature. Oxidation of HC and CO is good.
But the third pollutant is NOx, and NOx works just the opposite of HC and CO.... it has too much O2. Formation of NOx is promoted by higher combustion temperatures and by higher oxygen content. "Lean" makes NOx. Oxidation of nitrogen is bad.
So.... raise the temperature to complete the combustion of HC and CO. Then quench (lower) it when it gets too high, to prevent the formation of NOx. And, its the odd combination of moderate load and low RPM - lugging the engine up a hill in too high a gear - that generates the high combustion chamber temperatures. Surprisingly, that's a higher combustion temperature/residence time situation than WOT/max load/high RPM. Not sure if I could explain why.
  #36
Mizz96Z28's Avatar
The reason GM would intentionally make cars overheat is job security. If you buy a car and never have to do anything to it they make that initial profit of selling the car and thats it. But then if you go buy new heads because yours warped from overheating or have to take your car in to a GM dealership to fix the head gasket then they keep making money after the fact. Not a big deal but they want to keep making money off a car for as long as possible or want you to get sick of fixing your car and buy a brand new one from them.
Old May 8, 2003 | 12:57 PM
  #37
treyZ28's Avatar
absolutly not. Gm wants to make reliable car. in the words of eric bryan- product is king. GM is not in the position, and knows it, to make unreiable cars on purpose.
its not FILLING up the cylinder with inert gasses. just some as fred explained.
If you block off the EGR, you dont have this exhuast in there "taking up space" and you can put air in there that will burn
Old May 8, 2003 | 12:58 PM
  #38
Exhaust gasses displace air, and fuel rate is reduced correspondingly. As Trey points out, there is less fuel, less BTU's produced, lower temperature.
AND.... the combustion temperatures are also a function of the PERCENT O2 in the combustion chamber. Reduce the %O2 in the chamber and the combustion is more "controlled" and at a slower rate. Increase the %O2, and you increase the burn speed and the combustion becomes less "controlled". Nitrous (N2O) increases the %O2 in the combustion chamber, and speeds the burn rate. That's why you need to pull timing with nitrous... the combustion is faster. And the combustion temperatures increase. Try using pure O2 instead of N2O...... .
Old May 8, 2003 | 01:01 PM
  #39
treyZ28's Avatar
i'll stick to nitrous... it would explode or catch on fire
Old May 8, 2003 | 01:02 PM
  #40
Rpm280's Avatar
Originally posted by treyZ28
Rings or block, i want to say rings... but not 100% sure. I read this a while back, maybe a year ago or so.
I dont think our PCM retarts timing in relation to coolant temp
and coolant doesn't run through the LT1 intake
First of all, you need to read. I never said coolant runs through the lt1 intake, I said RADIANT HEAT to the intake.
( Although Coolant actually does go to the throttle body!) But again I was talking about radiant heat.
As far as the computer retarding timing in relation to coolant temp I'm NOT stating fact on that, so i will let someone else chime in. ( I actually had in mind how some programs like Hypertech use more timing with lower temp thermostats.) But anyways, radiant heat from the engine can increase intake maniflold and tube temps which I am almost certain will cause the computer to pull timing due to Higher IAT's.
You stated that the LT1 does not have coolant going throught it . I NEVER SAID IT DID! ( Although again, the throttle body does, and that is why some bypass it.) But I did not say coolant goes through the intake.
I said RADIANT HEAT would/could cause intake temps to increase (Ever notice how hot an lt1 intake is after you drive?), I Never said coolant running through the intake, or that there was coolant running throught the intake.
Pay attention.
The ideal would seem to be a WARMER engine temp for more complete combustion,(if you can keep the intake air cool) with a COOL intake charge. In cases where you see more power with low engine temps, it's most likely because of more timing being used because . NOT BECAUSE A COOL BLOCK or LOW COOLANT TEMP MAKES MORE POWER.
But again, IF you can control for this, and you can keep your INTAKE air cooler you could still keep more timing anyways , even though the engine temps might be warmer.
Anyways , you should read first, and have some Idea before you reply. And again, I ask like the person above what is silly about the post?
AND READ before you reply this time.
Old May 8, 2003 | 01:07 PM
  #41
You need oxygen for complete combustion. When the EGR system is activated, the exhaust gas replaces some of the O2. AND the PCM knows the EGR system is activated and reduces the amount of fuel it adds, to maintain the resired A/F ratio.
No.
You don't gain anything in the way of performance by blocking off the EGR. The EGR system only operates at part throttle. It never operates at WOT, so it has absolutle NO effect on performance, whether it is there or not.
You could speculate that there is some small temperature reduction in the intake manifold in the area of cyls #7 and #8, that nets you a slightly denser charge in the cylinders when there is no EGR heat connected to the intake manifold, but that's really a stretch.
You'll have to explain the meaning of "saturate"... not sure what you mean.
Old May 8, 2003 | 01:31 PM
  #42
Rpm280's Avatar
(Trey - you're dangerous when you get into some of these tech topics ).
TRUUUUUE THAT. Lol
Old May 8, 2003 | 01:41 PM
  #43
frmula1's Avatar
certain liquids are only chemically capable of holding a certain temperature.... and they cannot be heated beyond that... for instance if you tried to instantly raise the temperature of a gallon of water from 100 degrees to 300 it would "superboil" water, in its liquid form cannot be raised above the boiling point of 212 degrees F. when it does... it turns into steam... however when its in a sealed enviroment (like your cooling system) with no air present, and unable to expand into a gas because its under pressure... the liquid saturates... and is unable to absorb and more energy or heat because it has reached its tilt...
Old May 8, 2003 | 01:45 PM
  #44
Rpm280's Avatar
-increased thermal efficiency/power. Whoaaaa.... what did he say? YES, increasing the coolant temp means that LESS heat is removed from the combustion chambers. More heat is left in the combustion chambers, causing higher cylinder pressures, and more power to be produced. Wait a minute - contradicts the whole idea that lower coolant temps makes more power..... see below.
The engine is designed, as Trey points out, to operate at the 220degF coolant temps that everyone sees in a stock system. It isn't hurting anything. The risky area is the oil.... too many excursions of the temp over 230-250degF and the oil will start to burn. Here is where synthetics help a lot, because they can stand up to elevated temps better, withyout breaking down - but that's a side issue.
So...... why do we lower the coolant temp on the LT1 and "maybe" make more power.
-You can run more timing. I think this is all the HPP+ does when you select the lower fan on/off temps with the 160degF 'stat. I've seen dyno tests that pretty much prove that the ONLY power the HPP+ can add is due to the 160degF stat. Of course if you don't advance the timing, you won't gain this HP. You will have lost HP due to reduced thermal efficiency.
-although there is no coolant in the intake manifold, it does flow through the throttle body (at least in a stocker) and it does keep heat in the heads, which flows quite well into the aluminum intake manifold, and heats the air flowing through the intake. Appears that there is some gain from the reduced intake air temps that offset the loss in thermal efficiency.
I have never seen any practical evidence of unusual metal "wear" due to the 160degF t'stat. I know I ran one in my bolt-on engine for about 50K miles with no problems... the engine, bearings, cam, pistons, cylinder walls, etc. were like new when I pulled it apart at 65K miles. I still run the same old 160degF t'stat in my stroker, with the coolant set to hold 195degF. That temp was chosen based on the engine dyno tuning. So.... running at 165degF isn't necessarily the best point. It can only be arrived at with fairly extensive tuning of timing, coolant temp, A/F ratio, etc.
As far as retarding timing... I honestly don't know what the stock PCM does, because I don't use it, but I definitely have timing offset tables programmed into my MoTeC to pull timing based on coolant temp and inler air temp. Perfectly logical.
Thanks goodness! Injuneer to the rescue.
Suddently my post does not look so silly now, huh Treyz28.
My post basically is the same information Injuneer just gave, that a Warmer engine = more power from complete combustion, as long as intake temps are kept cool, and that it's mainly the timing that causeses an increase with lower coolant temps. Not a COOL BLOCK. RADIANT Heat is what can hurt if it gets to the intake air. I did NOT say there is coolant in the intake, (HOWERVER, again it does go through the throttle body). If you can keep the intake cool , a warmer engine is better for power. Plus you can add timing with cooler intake air.
Also notice the last part of his. I'm not an expert on the stock computer, but the idea of timing retard for a when coolant temps increase in not so silly.
Old May 8, 2003 | 02:21 PM
  #45
treyZ28's Avatar
by reading your post, i got the impression that that you were saying the pcm retards timing when coolant temps increase, afterall- we WERE TALKING about coolant temps and performance
"The ideal would seem to be, A nice warm block/coolant temp (TO A POINT), with a COOL intake temperature, and a computer programed to keep the timing from droping at certain engine temps."
Now we can sit here and argue who miscommunicated or who misunderstood- while you continualy say the same thing 18x in post ("RADIANT!") or we can give it up and move on with life.
Personaly, i chose the second. my ego is not so big that its going force me to sit here and argue with you. Personnaly, i think your explanation was confusing at best compared to freds explanation.
anywho, thanks fred for clarification, explaination and the emissions thing
