Anyone make 10mm x 3/8'studs to use LT4 RR on a sbc?
Old Jun 9, 2003 | 07:36 AM
red90sixspeed's Avatar
I know the hotcam kts come with the rr for 3/8th studs but if someone had a set of 10mm LT4 rr and needed to use them on a run of the mill sbc who makes a stud for that?
Old Jun 9, 2003 | 09:34 AM
LT4POWR's Avatar
Have you tried a chevy parts dealer?
Old Jun 9, 2003 | 02:04 PM
Actually yes...I work at one They cant find anything at all. I'm in parts dept right now as I type this. I guess I'm looking for a screw in stud that is 3/8 on the bottom and 10mm on top.
Old Jun 9, 2003 | 02:29 PM
Mtrhds94Z's Avatar
A 'real' LT4 stud SHOULD BE 3/8" on bottom and 10mm up top?[with a shoulder that the adj nut gets tightened down to?]
I wouldn't know a p/n tho..
LT1 studs are p/n 12552126
I did some checking and I believe the LT4 stud is p/n 12550011
[not sure of this but its something for you to check out..]
alliance12364
Mar 6, 2015 04:39 PM
95chwagon
Jan 13, 2015 09:19 PM
Catmaigne
Dec 25, 2014 12:16 PM
Sarahrope64
Nov 27, 2014 11:17 AM
