Anyone knows if our starter stays engaged???
Old Nov 10, 2003 | 11:25 AM
S.J.S.'s Avatar
I was just curious because I put my motor back together and cranked it. I was pre-oiling the motor and it sounded weird, that was because I had the plugs out it was just winding. I took off the converter cover and saw the starter engaged. It stays that way???
Old Nov 10, 2003 | 01:28 PM
S8ER95Z's Avatar
The starter drive should pull back away from the flywheel (Disengage).. Something isn't right.
Old Nov 10, 2003 | 01:35 PM
atljar's Avatar
NO it shouldnt be like that. I had one get stuck once after i put in a new starter. Had to kinda pry it out, and then it never happened again.
Old Nov 10, 2003 | 04:29 PM
S.J.S.'s Avatar
Fond out what it was. The starter will stay engaged until the motor rotates on its own then pressure is taken off of it allowing it to go back.
thanks for the help anyway guys.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
