Anyone know what cam this is??
Old Feb 16, 2006 | 05:35 PM
ajschult's Avatar
If I remember correctly it is from Comp, but I had no luck searching for any of these numbers on there website. There are three numbers on the cam:
395wb38 (looks like it was hand engraved)
01897L (stamped lettering)
700-136 (stamped lettering)
I used to have the specs for it, but have since lost them and have had no luck contacting the previous owner. If anyone has any ideas on how to find out what this cam is please let me know.
Andrew
Old Feb 16, 2006 | 07:34 PM
cammed_aro Z28's Avatar
Re: Anyone know what cam this is??
if it is a comp, i believe it should have a double stamped "c" on it, if so email those #'s to comp and they should help you.
Old Feb 17, 2006 | 11:49 AM
ajschult's Avatar
Anyone know if a machine shop can figure out cam specs?
Old Feb 17, 2006 | 02:44 PM
Max 93's Avatar
is this it? TPIS Cams
700-136 212/226 .483/.520 .515/.554 112deg ZZ-9
Old Feb 17, 2006 | 03:07 PM
Javier97Z28's Avatar
Moderator
has to be put on a cam doctor to find somewhat close specs...
best bet is to use the #'s you have.. that post above mine sounds like he's on it.
Old Feb 17, 2006 | 03:54 PM
94badrag's Avatar
If it's a comp cam then call there cam tech, read him the numbers and walla. It worked for me. If it's not thiers then try the TPIS.......
Old Feb 18, 2006 | 01:38 AM
ajschult's Avatar
I looked at that TPIS cam. Is TPIS a brand, because this came out of an LT1. I saw one page that listed that as an LT1 cam, but I thought TPI was a third gen car. Anyone have any input?
Old Feb 18, 2006 | 08:14 AM
Max 93's Avatar
http://www.tpis.com/index.php?module...%28L98+LT-1%29
Old Feb 18, 2006 | 08:53 AM
Moderator
TPIS sells LT1 stuff as well..
Old Feb 18, 2006 | 10:57 AM
ajschult's Avatar
ah... thanks guys
Andrew
Old Feb 18, 2006 | 11:28 AM
97WS6SCharged's Avatar
The only difference between a normal roller SBC cam and an LT1 cam is the dowel pin length.
Old Feb 18, 2006 | 08:55 PM
ajschult's Avatar
Suddenly it all makes sense.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
