Anyone know how to make a 94 body harness work with a 95 engine harness and computer?
Old Jun 2, 2005 | 11:59 AM
dbusch22's Avatar
the 94 body harness has ONE connector on the passenger shock tower and the 95 engine harness has TWO. Anyone who has dealt with this before please help? i don't want to have to find a 94 engine harness unless anyone has one they'd trade even for a 95. help!
Old Jun 3, 2005 | 10:38 AM
dbusch22's Avatar
Re: Anyone know how to make a 94 body harness work with a 95 engine harness and computer?
no one? i'm dyin' here
Old Jun 8, 2005 | 12:45 AM
madwolf's Avatar
Work needed on the C100 connector (black,10 cavity pass strut tower):
You will need to pull out/cut the Light Blue wire in cavity D on the forward lamp harness side. You will need to supply power from PCM fuse #8 to this wire.
Work needed on the C105 connector (black, 8 cavity pass strut tower, second connector of 95 harness)
You will need to supply power from Injector fuse #10 to the pink wire in cavity B. There is already a power feed from this fuse running to C100 to cavity K (pink wire) if you want to use the same wire. I would recommend running a new wire though.
The above should get your car running.
PS. You can try doing only the C100 change. It might work just with that.
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
